Idiots guide to setting up Orient
03 Apr 2018 20:39 #108337
by Ross77
Idiots guide to setting up Orient was created by Ross77
Pretty much as above. Is there an idiots guide for the Orient? I have seen Ralganlittlejohn's post where he kindly posted the HAL and INI files but it it for a mesa card and VFD settup.
I want to carry on with the Parra port and I have a DC motor, will that still work or do I need to start from scratch? I know I will need to build it up piece by piece and do lots more research but any pointers would be good so I know I'm going down the right path.
The spindle motor is 0.37kw 180v DC and the driver is a Sprint 340XRi 4 quadrant controler. using a 90 slot encoder disc with 2 sensors to give quadrature and a third sensor for the index. depending on how well the controller can brake I may need to add a brake as well.
Thanks in advance
Thanks in advance
05 Apr 2018 12:38 #108444
Replied by andypugh on topic Idiots guide to setting up Orient
The underlying logic is vaguely represented here:
wiki.linuxcnc.org/uploads/orient.svg
(Ctrl+ will make it big enough to read on most browsers)
You would need to change the VFD-Outputs block to suit your hardware interface. The rest should look much the same.
13 Apr 2018 20:49 #108967
by Ross77
Replied by Ross77 on topic Idiots guide to setting up Orient
If im honest thats still a bit over my head so I'll have to brush up on Hal and compare to RalganLittlejohns files, Now im setup with the mesa Im hoping i can just copy most of it.
I nearly have the spindle and encoder working so this is next on the list.
- raglanlittlejohn
- Thank you received: 9
14 Apr 2018 07:54 #108989
by raglanlittlejohn
Replied by raglanlittlejohn on topic Idiots guide to setting up Orient
Hi Ross77,
I think you will find the schematic I posted will be more helpful than the Hal/Ini files. The Hal/Ini files have closed loop steppers etc that may not be relevant to your set up. I did the schematic in LibreOffice Draw. I found this was the easiest way to plan the configuration. It's very difficult to work out what's going on with just the Hal/Ini files. It looks like your using a servo motor and driver?. I guess that should work very well for the orient function, better than a standard 3 phase motor.
Good luck with the project. It took me ages to get a working set up, but it's well worth the effort.
14 Apr 2018 09:08 #108990
by Ross77
Thanks John
I will make a start over the weekend. I dont have a servo but it is a 180v DC motor with a 4 quadrant controller so it can brake for position, but not holding. commands are still 0-10v control, enable and direction like a vfd.
Im using a 60 tooth gear and a thumb screw at the moment so yes it will be worth the work and save lots of time in the long run.
01 Mar 2019 17:02 #127441
by ayedurand
Replied by ayedurand on topic Idiots guide to setting up Orient
Would you be willing to post your HAL/Ini files? I have a MaxNC lathe with step-servos and I'd like to see how people implement this.
04 Mar 2019 21:21 #127732
by ayedurand
Nevermind. I don't have step-servos.
Moderators: piasdom
Time to create page: 0.259 seconds
