open loop servo tuning.
07 May 2019 03:15 #133016
by skvallab
Replied by skvallab on topic open loop servo tuning.
from linux cnc config picker,
list by interface -> PICO-> univstep-> univstep.
and generated my config files
07 May 2019 13:20 #133050
Replied by andypugh on topic open loop servo tuning.
In that case I would be very surprised if the config does not have following-error limits.
The following user(s) said Thank You: skvallab
07 May 2019 13:33 #133051
Replied by PCW on topic open loop servo tuning.
At least the example univstep.ini has these:
FERROR = 0.0100
MIN_FERROR = 0.001
( these settings would be way too small for a metric machine however )
FERROR = 0.0100
MIN_FERROR = 0.001
08 May 2019 09:11 #133117
by skvallab
I'm sorry, i checked they had
FERROR & MIN_FERROR values,
FERROR = 0.010
MIN_FERROR = 0.001
i use my system in mm config.
and open loop, i just want the linux cnc to give pulse and direction to my servo drive.
i tried changing the value
Ferror = 0.1
Min_Ferror = 0.4
rate of error has reduced, but still couldnt get my velocity high.
FERROR = 0.010
MIN_FERROR = 0.001
Ferror = 0.1
Min_Ferror = 0.4
08 May 2019 09:13 #133118
by skvallab
thanks , i increased the values
but still couldnt get my machine velocity to get high.
is there a way to disable linuxcnc 's PID generator., i just need it to give pulses, my servo drive can handle the PID.
08 May 2019 09:28 #133119
Do you have 25% more STEPGEN_* (velocity and acceleration) than the Axis is configured for?
Stepgen following errors simply mean that not enough steps have been sent to achive the target position (ie, the following errors you are seeing are _real_ and need to be configured away rather than ignored.
08 May 2019 09:32 #133120
by skvallab
Have increased the max_velocity of axis 1 = 505
pid-max-vel = 506
still not able to achieve my reqd. velocity.
my motor rated rpm is 1500, it looks like it is just running at 150 to 300 max.
pid-max-vel = 506
08 May 2019 10:08 #133121
by skvallab
Now i'm not getting errors. just velocity is low., PID max vel and max velocity has been increased and still i dont see difference in my servo's speed. it still stands the same
08 May 2019 11:49 #133130
How about the Axis, Joint and TRAJ velocities?
08 May 2019 11:58 #133131
by skvallab
i entering all values of 1 axis which has low velocity below
[traj]
default velocity = 0.167
max_velocity = 100
default acceleration = 30
max acceleration = 500
stepgen maxaccel =750
axis_1
type = angular
home = 0.0
max_velocity = 1005
max_acceleration = 500
pid_max_vel = 1006
backlash = 0.0
scale = 100
output scale = 1
min_limit = -3600
max_limit =3600
ferror = 0.1
min_ferror = 0.2
home offset=0.0
home search vel =0.0
home latch vel = 0.0
home use index = no
home ignore limits = no
deadband = 0.01
p=300
i=100
d=0.1
bias=0.0
ff0=0.0005
ff1=1
ff2=0.0005
[traj]
max_velocity = 100
axis_1
type = angular
home = 0.0
max_velocity = 1005
pid_max_vel = 1006
backlash = 0.0
scale = 100
output scale = 1
min_limit = -3600
max_limit =3600
ferror = 0.1
min_ferror = 0.2
home offset=0.0
home use index = no
deadband = 0.01
p=300
i=100
d=0.1
bias=0.0
ff0=0.0005
ff1=1
ff2=0.0005
Moderators: piasdom
