old cnc lathe retrofit
03 Jun 2019 13:43 #135747
by pl7i92
Replied by pl7i92 on topic old cnc lathe retrofit
yes it is awaysome good condition
so keep all parts just rewirer to a better and understandable Control like 7i77
you can go with a 7i92 to a ethernetcnc controlled mashine
BUT first if you can move the mashine by Auto or manuell mode check if the drives are analog 0-10V at that time
or newly +-10V as the 7i77 is sopost to run
04 Jun 2019 16:32 - 04 Jun 2019 16:33 #135845
by vre
Replied by vre on topic old cnc lathe retrofit
It is not my machine in the photos it is a same model machine.
Mine is in used condition not like new as this in the photos.
But i found way how to regrind ways or use linear rails if needed.
Last edit: 04 Jun 2019 16:33 by vre.
Moderators: piasdom
Time to create page: 0.133 seconds
