Enco 9x20 build - Steppers not moving!!
02 Apr 2020 00:46 - 02 Apr 2020 01:15 #162418
by Jdub
Enco 9x20 lathe build - Steppers not moving!! was created by Jdub
Hi everyone!
Trying to get my conversion completed with this Covid-19 vacation!!
Got the machine built and just finished up the cabinet - wired up the steppers and they are not responding. I believe they are getting power as they lock tight when power is turned on.
Pretty sure this is the stepper kit I have - bought it 3-4 years ago: www.automationtechnologiesinc.com/produc...6050-stepper-driver/
Here is the wiring diagram I used minus the "Y" axis: www.automationtechnologiesinc.com/wp-con...014/09/ALLDriver.pdf
I did wire in a relay to start and stop the spindle motor and it does work as it is supposed to so i assume the 25 pin cable is good - i did ohm it pin to pin and it checked good.
Can you folks look over the attached pictures? I probably just missed something stupid and keep looking past it as I troubleshoot.
I do have a CNC retrofit mini mill also with LinuxCNC that I bought already built and have used for years - so I probably understand just enough to be dangerous!! LOL!
Thanks, Jeff
Thanks, Jeff
Last edit: 02 Apr 2020 01:15 by Jdub.
- Thank you received: 5945
02 Apr 2020 00:55 #162419
Replied by tommylight on topic Enco 9x20 build - Steppers not moving!!
That picture does not help.
Do the motors lock when you turn on the power ? Try to move them by hand while powered, they should not move, at least not easily.
Upload your hal and ini files so we can have a look.
First thing would be to check the wiring to the drives, then setting the step time and step space to 10000 or 15000.
Also do you get the latency error when enabling Linuxcnc?
02 Apr 2020 00:58 - 02 Apr 2020 01:07 #162420
by Jdub
Replied by Jdub on topic Enco 9x20 build - Steppers not moving!!
I am trying to add more pictures - they were too large of file sizes!
Bear with me....
Bear with me....
Last edit: 02 Apr 2020 01:07 by Jdub.
02 Apr 2020 01:10 #162422
by Jdub
Yes, the motors are locked when power is on - once you turn off the power you can turn them .
No latency error.
No latency error.
02 Apr 2020 01:35 #162423
Microsteping can not be 1.8. Look at the drives and check at what microstepping are they set, then put that in the stepconf.
Set step time and step space to 10000, in the stepconf.
Test, repost back.
Test, repost back.
02 Apr 2020 01:57 - 02 Apr 2020 02:04 #162424
by Jdub
Okay, driver dip switches are set to 2 micro steps (switch 5 off, 6,7 and 8 on) - changed both X & Z stepconf to 2.0.
Changed step time and step space to 10000 in stepconf and it didn't get the motors moving.
Last edit: 02 Apr 2020 02:04 by Jdub.
02 Apr 2020 08:25 #162433
by Clive S
Replied by Clive S on topic Enco 9x20 build - Steppers not moving!!
How is the BOB being powered as looking at pic3 I only see one lead going into the power on the BOB
The following user(s) said Thank You: Jdub
- Mike_Eitel
- Thank you received: 185
02 Apr 2020 15:53 #162458
by Mike_Eitel
Replied by Mike_Eitel on topic Enco 9x20 build - Steppers not moving!!
If i interpret correct you can set the 'commons' of your outputs to either gnd or 5v plus eventually pullups. Try to measure if your outputs have signals on the bourns.
02 Apr 2020 22:34 - 02 Apr 2020 22:58 #162504
by Jdub
Clive,
In the bottom left corner is the 5V power supply - I wired it according to this diagram www.automationtechnologiesinc.com/wp-con...014/09/ALLDriver.pdf
Am I missing something else?
Thanks, Jeff
Thanks, Jeff
Last edit: 02 Apr 2020 22:58 by Jdub.
02 Apr 2020 22:42 #162506
by Jdub
Mike,
Are these "commons" on the BOB between outputs 2&3 {X axis} and 6&7 {Z axis} ??
How do I check them? I have a multimeter- assuming they will be 48VDC - when do I check them? When attempting to move the axis?
Thanks, Jeff
Thanks, Jeff
Moderators: piasdom
Time to create page: 0.544 seconds
