Enco 9x20 build - Steppers not moving!!
02 Apr 2020 22:43 #162508
by Jdub
Replied by Jdub on topic Enco 9x20 build - Steppers not moving!!
.INI File
# Generated by stepconf 1.1 at Wed Apr 1 16:54:24 2020
# overwritten when you run stepconf again
[EMC]
MACHINE = my-lathe
DEBUG = 0
[DISPLAY]
DISPLAY = axis
EDITOR = gedit
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
ARCDIVISION = 64
GRIDS = 10mm 20mm 50mm 100mm 1in 2in 5in 10in
MAX_FEED_OVERRIDE = 1.2
MIN_SPINDLE_OVERRIDE = 0.5
MAX_SPINDLE_OVERRIDE = 1.2
DEFAULT_LINEAR_VELOCITY = 0.10
MIN_LINEAR_VELOCITY = 0
MAX_LINEAR_VELOCITY = 1.00
INTRO_TIME = 5
PROGRAM_PREFIX = /home/owner/linuxcnc/nc_files
INCREMENTS = .1in .05in .01in .005in .001in .0005in .0001in
LATHE = 1
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
BASE_PERIOD = 100000
SERVO_PERIOD = 1000000
[HAL]
HALFILE = my-lathe.hal
HALFILE = custom.hal
POSTGUI_HALFILE = custom_postgui.hal
[TRAJ]
AXES = 3
COORDINATES = X Z
LINEAR_UNITS = inch
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 0.10
MAX_VELOCITY = 1.00
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 1.0
MAX_ACCELERATION = 30.0
STEPGEN_MAXACCEL = 37.5
SCALE = 2540.0
FERROR = 0.05
MIN_FERROR = 0.01
MIN_LIMIT = -0.01
MAX_LIMIT = 8.0
HOME_OFFSET = 0.0
[AXIS_2]
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 1.0
SCALE = 2000.0
FERROR = 0.05
MIN_FERROR = 0.01
MIN_LIMIT = -4.0
MAX_LIMIT = 4.0
HOME_OFFSET = 0.0
[EMC]
MACHINE = my-lathe
DEBUG = 0
[DISPLAY]
DISPLAY = axis
EDITOR = gedit
ARCDIVISION = 64
INTRO_TIME = 5
LATHE = 1
[FILTER]
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
[HAL]
[TRAJ]
AXES = 3
COORDINATES = X Z
LINEAR_UNITS = inch
CYCLE_TIME = 0.010
MAX_VELOCITY = 1.00
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 1.0
SCALE = 2540.0
FERROR = 0.05
MIN_FERROR = 0.01
MIN_LIMIT = -0.01
MAX_LIMIT = 8.0
HOME_OFFSET = 0.0
[AXIS_2]
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 1.0
SCALE = 2000.0
FERROR = 0.05
MIN_FERROR = 0.01
MIN_LIMIT = -4.0
MAX_LIMIT = 4.0
HOME_OFFSET = 0.0
02 Apr 2020 22:56 #162513
by Jdub
HAL file
loadrt trivkins
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
loadrt hal_parport cfg="0 out"
loadrt stepgen step_type=0,0
loadrt pwmgen output_type=1
addf pwmgen.make-pulses base-thread
addf stepgen.update-freq servo-thread
net spindle-cmd-rpm => pwmgen.0.value
net spindle-on <= motion.spindle-on => pwmgen.0.enable
net spindle-pwm <= pwmgen.0.pwm
setp pwmgen.0.pwm-freq 100.0
setp pwmgen.0.scale 1166.66666667
setp pwmgen.0.offset 0.114285714286
setp pwmgen.0.dither-pwm true
net spindle-cmd-rpm <= motion.spindle-speed-out
net spindle-cmd-rpm-abs <= motion.spindle-speed-out-abs
net spindle-cmd-rps <= motion.spindle-speed-out-rps
net spindle-cmd-rps-abs <= motion.spindle-speed-out-rps-abs
net spindle-at-speed => motion.spindle-at-speed
net spindle-cw <= motion.spindle-forward
net xstep => parport.0.pin-02-out
net xdir => parport.0.pin-03-out
net zstep => parport.0.pin-06-out
net zdir => parport.0.pin-07-out
net spindle-pwm => parport.0.pin-16-out
net spindle-cw => parport.0.pin-17-out
setp stepgen.0.position-scale [AXIS_0]SCALE
setp stepgen.0.steplen 1
setp stepgen.0.stepspace 1
setp stepgen.0.dirhold 36000
setp stepgen.0.dirsetup 36000
setp stepgen.0.maxaccel [AXIS_0]STEPGEN_MAXACCEL
net xpos-cmd axis.0.motor-pos-cmd => stepgen.0.position-cmd
net xpos-fb stepgen.0.position-fb => axis.0.motor-pos-fb
net xstep <= stepgen.0.step
net xdir <= stepgen.0.dir
net xenable axis.0.amp-enable-out => stepgen.0.enable
setp stepgen.1.position-scale [AXIS_2]SCALE
setp stepgen.1.steplen 1
setp stepgen.1.stepspace 1
setp stepgen.1.dirhold 36000
setp stepgen.1.dirsetup 36000
setp stepgen.1.maxaccel [AXIS_2]STEPGEN_MAXACCEL
net zpos-cmd axis.2.motor-pos-cmd => stepgen.1.position-cmd
net zpos-fb stepgen.1.position-fb => axis.2.motor-pos-fb
net zstep <= stepgen.1.step
net zdir <= stepgen.1.dir
net zenable axis.2.amp-enable-out => stepgen.1.enable
net estop-out => iocontrol.0.emc-enable-in
net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
loadrt trivkins
- Thank you received: 5945
03 Apr 2020 01:22 #162522
Replied by tommylight on topic Enco 9x20 build - Steppers not moving!!
The COM jumper is not set correctly on the BOB, you have the drives wired as common 5V but the BOB is still set for common GND.
The following user(s) said Thank You: Jdub
03 Apr 2020 01:41 #162524
by Jdub
Tom - that was it!! It moves now!!
I didn't realize that the 5V was needed on the common - the comment by Mike above got me to do some googling it this evening and I saw that there was a jumper on the BOB - you confirmed it!!
Thanks so much to everyone who replied!!
Jeff
Jeff
03 Apr 2020 08:19 #162545
by Clive S
Replied by Clive S on topic Enco 9x20 build - Steppers not moving!!
Yes the night shift sorted it. Glad you have it working:)
Moderators: piasdom
Time to create page: 0.509 seconds
