Hyundai 18s hit sinumerik 840c
27 Oct 2020 13:56 #187415
Replied by Aciera on topic Hyundai 18s hit sinumerik 840c
So it looks like you are well documented. Nice, that will save you hours trying to follow the wiring around the machine.
I can just barely read it but that is the coolant and hydraulics. On the right are the drives but only the over view. Maybe a bit further you will find the servo motors.
27 Oct 2020 14:00 #187417
by Torus13
Replied by Torus13 on topic Hyundai 18s hit sinumerik 840c
I propably have every book for this machines from part list, to parameters and electric or errors but i have lot of problems with this siemens langue is Czech i use Polish or English i dont have password for plc so i cant change it thats why i consider retrofit i cant afford that long brakes in my workshop actually 2 weeks
27 Oct 2020 14:13 #187419
Well, while I think it may well be possible to get this machine back up and running with LinuxCNC I don't think you will get this done in 2 weeks.
- Thank you received: 1370
27 Oct 2020 14:26 #187420
Replied by Todd Zuercher on topic Hyundai 18s hit sinumerik 840c
Probably in that book but those don't look like the right pages. (Those look like wiring for the coolant pump motor and other non servo motors.)
27 Oct 2020 14:30 #187421
by Torus13
How Long it mat take i propably gonna find someone who may help me and what i also need mesa 7i77 and 5i25?
27 Oct 2020 14:33 #187422
Yes, 2 weeks for a full retrofit to Linuxcnc might be possible if you know what you are doing. Sounds very optimistic for a first timer, especially on a complex full featured machine. Especially if the machine as bugs and issues that will still need fixed.
27 Oct 2020 14:44 - 27 Oct 2020 14:50 #187425
The mesa boards: eusurplus.com/index.php?route=product/search&search=7i77
Delivery has always been very fast for me (2-3days). But then those need to be wired and then the configuration will need to be set up.
Impossible to say how much time that will take. If you have somebody who knows the boards and LinuxCNC and everything works together then 2 weeks might actually be realistic but if you need to learn the system as you go then it will take a lot longer.
In any case, since you have all the documentation, you would want to get a clear concept of how things are going to be connected to the mesa boards. Position feedback to linuxCNC is the first that would need to be clear (The 7i77 needs encoder inputs if I am not mistaken) May be your drive provides a simulated encoder output to feed back to LinuxCNC but I don't know.
Note that the user in the thread I posted earlier seems to have added incremental encoders to the motors as a feedback to the 7i77 and LinuxCNC
Last edit: 27 Oct 2020 14:50 by Aciera.
27 Oct 2020 18:49 - 27 Oct 2020 18:51 #187453
by aleksamc
Replied by aleksamc on topic Hyundai 18s hit sinumerik 840c
This is your machine?
It will be hard to renew it.
I was interested in such machine some time. May be you want to sell it?
I'm from Ukraine and is interested in such one even not workable.
Last edit: 27 Oct 2020 18:51 by aleksamc.
27 Oct 2020 19:59 - 27 Oct 2020 20:00 #187460
by Torus13
Yes this is that machine its hard to say for me now i hate her but it is very good machine i used to work on 3years old okuma lb3000 spaceturn ii and genos 200 this machine in two axis beat them like pro ... 72mm spindle hole etc mechanicly this machine is awesome i do lot of parts in H7 h7 tolerances
Difference beetwen machine from youtube is that i dont have mounted drills etc. like that but on outside on blocks
Last edit: 27 Oct 2020 20:00 by Torus13.
27 Oct 2020 21:40 - 27 Oct 2020 21:42 #187477
by aleksamc
Can you make some photos of it? How does it looks? Photos of is installed devices in cabinets.
Last edit: 27 Oct 2020 21:42 by aleksamc.
Moderators: piasdom
Time to create page: 0.103 seconds
