Use PWM instead of Potentiometer VFD
12 Jan 2021 20:30 #195115
by Anonymous
Use PWM instead of Potentiometer VFD was created by Anonymous
I have a VFD which controlls the spindle motor on my lathe.
It is currently hooked up to a Potentiometer to be controlled by hand but i want to controll it with a PWM signal.
Can i just hook up the PWM signal to the VFD instead of the potentiometer? Or will that not work?
12 Jan 2021 21:25 #195124
Replied by andypugh on topic Use PWM instead of Potentiometer VFD
It depends on the VFD, but probably.
What is generating the PWM?
Here is a simple circuit than can be used to make a PWM look like a potentiometer to the VFD:
photos.app.goo.gl/cFtC9m7CeLSKASAa7
13 Jan 2021 00:19 #195157
by Benb
Replied by Benb on topic Use PWM instead of Potentiometer VFD
An other alternative is to purchase ready made board they cost about $6:
opencircuit.shop/Product/PWM-to-Analog-0-10V-Converter-Module
www.aliexpress.com/i/32844261017.html
Ifyou google analog 0-10v to pwd converter you will probably find a supplier in your area.
Moderators: piasdom
Time to create page: 0.063 seconds
