Manual tapers
13 Jan 2021 08:54 #195196
by anfänger
Manual tapers was created by anfänger
I will have two mpg for x and z axis, so i can use the lathe in „manual mode“ when I want to do simple operations.
I wonder if there is an easy way to give the z axis an angle for cutting a taper manually?
Thanks Patrick
Thanks Patrick
13 Jan 2021 09:11 #195197
Replied by andypugh on topic Manual tapers
For simple operations I use: forum.linuxcnc.org/41-guis/26550-lathe-macros
The ability to cut tapers is built-in to the turning, facing and boring tabs.
The following user(s) said Thank You: anfänger
13 Jan 2021 09:37 - 13 Jan 2021 09:39 #195200
by anfänger
Replied by anfänger on topic Manual tapers
Thanks I‘ll have a deeper look at them, cause they look very useful maybe moving them to qtpyvcp cause I am using this at my mill and I am kind of used to it
I was thinking about moving the the X and Z together at an angle and was wandering if it can be done in hal.
Last edit: 13 Jan 2021 09:39 by anfänger.
13 Jan 2021 10:13 - 13 Jan 2021 10:27 #195201
Yes, quite easily.
Potentially using a HAL sum2 component: linuxcnc.org/docs/2.8/html/man/man9/sum2.9.html
You could sum Z and X before passing to the motor, with gain1 set to zero normally, but set to a value (halcmd prompt) as needed.
But, really, you might as well use CNC.
Here is an example of my macros in use (including a taper):
Yes, quite easily.
Last edit: 13 Jan 2021 10:27 by andypugh.
13 Jan 2021 10:13 #195202
You could use external offsets to achieve this
Replied by rodw on topic Manual tapers
13 Jan 2021 10:24 #195203
Probably better, as that will better comply to joint limits.
But I still don't think it is a sensible idea
13 Jan 2021 10:44 #195204
by anfänger
You are probably right
but external offset by angle sounds interesting.
I thin I will start wit the macros and if i need to waste more time I will dive into my braindead ideas.
13 Jan 2021 10:49 #195205
If you are running LinuxCNC 2.8 / 2.8.1 then there is a sample config in sim/gmoccapy/lathe-configs/lathe macros with the macros all set up and ready to play with.
13 Jan 2021 10:59 #195206
by anfänger
Good to know the I will start with gmocappy, though I prefer the look of qtpyvcp.
I hope I‘ll get the missing parts, so I can start assembling the control for my lathe.
13 Jan 2021 11:52 #195207
Moderators: piasdom
Time to create page: 0.173 seconds
