Screen and keyboard mounting ideas ???
15 Jan 2021 21:19 #195488
by mooser
Screen and keyboard mounting ideas ??? was created by mooser
I currently have my screen and keyboard on a semi-articulated arm that is bolted to the wall near the tailstock end of the lathe (SM series 2000)
That location tends to work better for me than when I had it up on the headstock end.
I need to move the wall mount and I'm thinking I'd like to see what others have for their setup incase something jumps out at me rather than what I have now
So post up whatever/however you have your monitor/keypad/mpg for your lathes
M
M
19 Jan 2021 10:28 #195877
Replied by rodw on topic Screen and keyboard mounting ideas ???
19 Jan 2021 16:18 #195900
by mooser
Replied by mooser on topic Screen and keyboard mounting ideas ???
How are you planning on mounting?
I'm just using a normal screen/keyboard (nowhere near as nice a setup as you've got going there) but need to find a different arm or something to hold it since I needed to remove my old setup (fairly barbaric)
M
M
19 Jan 2021 21:05 #195917
by aleksamc
Replied by aleksamc on topic Screen and keyboard mounting ideas ???
- Thank you received: 5944
19 Jan 2021 21:39 #195923
Replied by tommylight on topic Screen and keyboard mounting ideas ???
LOL, damn that is a nice one!
19 Jan 2021 21:56 #195924
I will just have 4 holes on the back and use a VESA mount. Another option might be to hang it from above. There are commercially available HMI mounting systems that do this and let it swivel
I have thought about having a seperate keyboard tray that mounts to the bottom and use a combo keyboard and trackball. It would just bolt on.
M
19 Jan 2021 22:36 #195931
by mooser
If I sat my butt on that I'd probably come up with better g-code than I normally do...
M
Just use your imagination
M
19 Jan 2021 23:54 - 19 Jan 2021 23:56 #195947
Replied by andypugh on topic Screen and keyboard mounting ideas ???
photos.app.goo.gl/DRi4Aa37nc7xg97a6
VESA arm mount bolted to a panel on the back of the headstock.
MPGs mounted on the saddle.
(Ignore the keyboard, that lives in the house and is brought into the workshop only as needed)
Last edit: 19 Jan 2021 23:56 by andypugh.
20 Jan 2021 00:05 #195949
Every time you share that photo, I just have to look at it to admire your handiwork Andy!
The following user(s) said Thank You: CORBETT
20 Jan 2021 00:22 #195955
+1
Moderators: piasdom
Time to create page: 0.191 seconds
