Schaublin 125-CNC retrofit.
Yes its pretty cool! I was surprised how easy it was to code. Without the state machine there would be lots of nested if/else spaghetti code!I didn't realise how simple and elegant it is to set up a state machine in a comp.
The hard bit is often to decide what algorithm to use. If you get it wrong, it can be a lot harder than it needs to be.
its an ideal demonstrateion what a component should look like. Short (68 lines) with a single, clearly defined problem being solved.
Why I've never used classic ladder.
- smc.collins
- Thank you received: 110
I'd think the contactors would be kinda difficult to switch accurately for short durations.
Mark, put some flyback diodes in the contactor dc coil circuit, i was thinking this might be flyback voltage
that's a nifty little program, I'm curious to see how accurately it can control the variator.
Thanks, me too.
I just realized it needs an enable pin becasue from the original video, it is not allowed to move without the spindle turning. Something like:
pin in bit enable = 0 "set true when spindle is running with spindle.0.on";
if (!enable) //insert before switch statement
return;
Would flyback voltage still spike and cause issues if the contactors are manually activated (i.e. screwdriver)? I'm genuinely curious.Mark, put some flyback diodes in the contactor dc coil circuit, i was thinking this might be flyback voltage
- Thank you received: 5983
So am i.
Given that there is no energy stored in the inductor (ie no collapsing magnetic field) I don't see where that voltage would come from.Would flyback voltage still spike and cause issues if the contactors are manually activated (i.e. screwdriver)? I'm genuinely curious.
Me either, but I don't know everything about magic smoke. Like maybe there's some sort of induced field in the coil when the main contacts make/break - and I've never learned about this situation but it's obvious to everyone else.
Once the magic smoke discussion moves past my internal understanding of "electricity is like water through a hose, only not" I have to start asking questions.
- smc.collins
a typical 24vdc contactor coil has a impedance of around 30-50 ohm. The flyback voltage could easily reach 140-200v on coil off especially if the contacts bounce as the field collapses. It's worth a look. ALOT of DC coils have built in diodes to prevent this, but maybe this unit does not.
