Luxturn LTI Lathe Retrofit
- Bassblaster
27 May 2021 21:23 - 27 May 2021 21:25 #210466
by Bassblaster
Luxturn LTI Lathe Retrofit was created by Bassblaster
Hi guys,
I want to share my experience retrofitting a 30 year old Japanese lathe that I lovingly call "Wakako".(From Cyberpunk 2077)
This is her in full 'old' glory:
I am mostly posting this to share my pain as I am trying to enable her features, but also to maybe get some advice.
I am using a Mesa 7i96 card connected via ethernet to a Dell Optiplex running Debian 10 and Linux 2.8.0 .
The old lady sure is a little troublemaker, but so far, I got the x- and z-axis moving.
The next tasks will be:
After everything is finished, I want to make a tutorial video on Youtube so that other people have an easier time (is that even possible? )
Kind regards,
Manuel
- Get the limit switches etc. connected and make sure they are working
- Get the mesa board to output a PWM signal for the VFD for the main spindle
- Get the spindle encoder to work with the mesa Board
- Try to get the revolver-style ATC running
Kind regards,
Manuel
Last edit: 27 May 2021 21:25 by Bassblaster.
The following user(s) said Thank You: tommylight, Moezzz
- Thank you received: 5944
27 May 2021 21:42 #210470
Replied by tommylight on topic Luxturn LTI Lathe Retrofit
That is a nice little lady !
The following user(s) said Thank You: Bassblaster
- Bassblaster
28 May 2021 23:27 - 28 May 2021 23:28 #210568
by Bassblaster
Replied by Bassblaster on topic Luxturn LTI Lathe Retrofit
Today, I made some more progress.
I used PnCConf tool to get an initial config. This way, I was able to get the limit switches and the coolant pump and so on working.
My Lathe already had a spindle encoder, and I wanted to keep it in order to avoid additional work on the hardware side of things.
Fortunately, I got the stock spindle encoder to work changing the jumpers on the mesa 7i96 board according to the manual for a single ended encoder. The encoder was a little bit confusing, because it has 8 wires coming out, but 4 of them need to be grounded, so it is indeed single ended:
I was able to verify the working state of the encoder using halshow, The structure of the parameters wasn't intuitive in my opinion, but we can see it working here:
Unfortenately, getting the mesa card to output a pwm signal for the spindle is appearantly not as easy. I did the following steps:
My first guess is that I have to change more in the .hal file. Does anyone have a clue what to change? Or an example of a .hal file from an 7i96 with pwm spindle control?
- Flashing the mesacard with the firmware for 4 stepgens and 1 pwm generator using mesaflash
- I then changed the .hal file manually, since PnCConf seems to have a problem with the custom firmware. I only changed one line, in which I specified the number of pwm gens to be 1.
- Running mesaflash --device 7i96 --addr 10.10.10.10 -readhmid ,I found out the pins, where the pwm generator was assigned to.
- Then I connected an oscilloscope (to pins 1 and 3 of TB2 in my case), but was not able to get any signal.
Last edit: 28 May 2021 23:28 by Bassblaster.
29 May 2021 01:58 #210580
Replied by PCW on topic Luxturn LTI Lathe Retrofit
Can you post your current hal and ini files?
- Bassblaster
30 May 2021 20:02 - 30 May 2021 20:03 #210728
by Bassblaster
Here are the .ini and the .hal , I think that in the .hal I might need to specify a pin for the PWM, I took a look at RotarySMP's ini and hal files for the minilathe, but couldn't get it to work for me.
This is the .ini:
And this is the hal:
This is the .ini:
# Erstellt von PNCconf am Sun May 30 21:54:52 2021
# Using LinuxCNC version: 2.8
# Änderungen an dieser Datei werden beim nächsten
# overwritten when you run PNCconf again
[EMC]
MACHINE = Wakako
DEBUG = 0
VERSION = 1.1
[DISPLAY]
DISPLAY = gmoccapy
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 2.000000
MAX_SPINDLE_OVERRIDE = 1.500000
MIN_SPINDLE_OVERRIDE = 0.500000
INTRO_TIME = 5
PROGRAM_PREFIX = /home/wakako/linuxcnc/nc_files
INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm
LATHE = 1
DEFAULT_LINEAR_VELOCITY = 6.000000
MAX_LINEAR_VELOCITY = 25.000000
MIN_LINEAR_VELOCITY = 0.500000
DEFAULT_ANGULAR_VELOCITY = 12.000000
MAX_ANGULAR_VELOCITY = 180.000000
MIN_ANGULAR_VELOCITY = 1.666667
EDITOR = gedit
GEOMETRY = xz
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
SERVO_PERIOD = 1000000
[HMOT]
CARD0=hm2_7i96.0
[HAL]
HALUI = halui
HALFILE = Wakako.hal
HALFILE = custom.hal
POSTGUI_HALFILE = postgui_call_list.hal
SHUTDOWN = shutdown.hal
[HALUI]
[KINS]
JOINTS = 2
KINEMATICS = trivkins coordinates=XZ
[TRAJ]
COORDINATES = XZ
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
DEFAULT_LINEAR_VELOCITY = 3.33
MAX_LINEAR_VELOCITY = 33.33
NO_FORCE_HOMING = 1
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
[AXIS_X]
MAX_VELOCITY = 33.3333333333
MAX_ACCELERATION = 100.0
MIN_LIMIT = -0.0
MAX_LIMIT = 140.0
[JOINT_0]
TYPE = LINEAR
HOME = 10.0
FERROR = 10.0
MIN_FERROR = 1.0
STEPGEN_MAXVEL = 41.67
STEPGEN_MAXACCEL = 125.00
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
# these are in nanoseconds
DIRSETUP = 10000
DIRHOLD = 10000
STEPLEN = 5000
STEPSPACE = 5000
STEP_SCALE = 5120.0
MIN_LIMIT = -0.0
MAX_LIMIT = 140.0
HOME_OFFSET = 0.000000
HOME_SEARCH_VEL = -1.000000
HOME_LATCH_VEL = -0.500000
HOME_FINAL_VEL = 0.000000
HOME_USE_INDEX = NO
HOME_SEQUENCE = 1
[AXIS_Z]
MIN_LIMIT = -350.0
MAX_LIMIT = 0.0
[JOINT_1]
TYPE = LINEAR
HOME = -20.0
FERROR = 10.0
MIN_FERROR = 1.0
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP = 10000
DIRHOLD = 10000
STEPLEN = 5000
STEPSPACE = 5000
STEP_SCALE = 5120.0
MIN_LIMIT = -350.0
MAX_LIMIT = 0.0
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
[SPINDLE_0]
P = 0.0
I = 0.0
D = 0.0
FF0 = 1.0
FF1 = 0.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 1500.0
ENCODER_SCALE = 1024.0
loadrt [KINS]KINEMATICS
loadrt hostmot2
loadrt hm2_eth board_ip="10.10.10.10" config=" num_encoders=1 num_pwmgens=1 num_stepgens=3 sserial_port_0=00xxxx"
setp [HMOT](CARD0).watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.z,pid.s
loadrt scale names=scale.gear
loadrt mux16 names=ratio_select
addf [HMOT](CARD0).read servo-thread
addf pid.x.do-pid-calcs servo-thread
addf pid.z.do-pid-calcs servo-thread
addf pid.s.do-pid-calcs servo-thread
addf ratio_select servo-thread
addf scale.gear servo-thread
addf [HMOT](CARD0).write servo-thread
# external output signals
# --- COOLANT-FLOOD ---
net coolant-flood => [HMOT](CARD0).ssr.00.out-00
# --- SPINDLE-ENABLE ---
net spindle-enable => [HMOT](CARD0).ssr.00.out-01
# --- SPINDLE-CW ---
net spindle-cw => [HMOT](CARD0).ssr.00.out-02
# --- SPINDLE-CCW ---
net spindle-ccw => [HMOT](CARD0).ssr.00.out-03
# --- MACHINE-IS-ENABLED ---
net machine-is-enabled => [HMOT](CARD0).ssr.00.out-04
# --- DOUT-00 ---
net dout-00 => [HMOT](CARD0).ssr.00.out-05
# external input signals
# --- MIN-X ---
net min-x <= [HMOT](CARD0).gpio.000.in
# --- MAX-X ---
net max-x <= [HMOT](CARD0).gpio.001.in
# --- HOME-X ---
net home-x <= [HMOT](CARD0).gpio.002.in
# --- MIN-Z ---
net min-z <= [HMOT](CARD0).gpio.003.in
# --- MAX-Z ---
net max-z <= [HMOT](CARD0).gpio.004.in
# --- HOME-Z ---
net home-z <= [HMOT](CARD0).gpio.005.in
# AXIS X JOINT 0
setp pid.x.Pgain [JOINT_0]P
setp pid.x.Igain [JOINT_0]I
setp pid.x.Dgain [JOINT_0]D
setp pid.x.bias [JOINT_0]BIAS
setp pid.x.FF0 [JOINT_0]FF0
setp pid.x.FF1 [JOINT_0]FF1
setp pid.x.FF2 [JOINT_0]FF2
setp pid.x.deadband [JOINT_0]DEADBAND
setp pid.x.maxoutput [JOINT_0]MAX_OUTPUT
setp pid.x.error-previous-target true
# This setting is to limit bogus stepgen
# velocity corrections caused by position
# feedback sample time jitter.
setp pid.x.maxerror 0.012700
net x-index-enable <=> pid.x.index-enable
net x-enable => pid.x.enable
net x-pos-cmd => pid.x.command
net x-pos-fb => pid.x.feedback
net x-output <= pid.x.output
# Step Gen signals/setup
setp [HMOT](CARD0).stepgen.00.dirsetup [JOINT_0]DIRSETUP
setp [HMOT](CARD0).stepgen.00.dirhold [JOINT_0]DIRHOLD
setp [HMOT](CARD0).stepgen.00.steplen [JOINT_0]STEPLEN
setp [HMOT](CARD0).stepgen.00.stepspace [JOINT_0]STEPSPACE
setp [HMOT](CARD0).stepgen.00.position-scale [JOINT_0]STEP_SCALE
setp [HMOT](CARD0).stepgen.00.step_type 0
setp [HMOT](CARD0).stepgen.00.control-type 1
setp [HMOT](CARD0).stepgen.00.maxaccel [JOINT_0]STEPGEN_MAXACCEL
setp [HMOT](CARD0).stepgen.00.maxvel [JOINT_0]STEPGEN_MAXVEL
setp [HMOT](CARD0).stepgen.00.step.invert_output true
setp [HMOT](CARD0).stepgen.00.direction.invert_output true
# ---closedloop stepper signals---
net x-pos-cmd <= joint.0.motor-pos-cmd
net x-vel-cmd <= joint.0.vel-cmd
net x-output <= [HMOT](CARD0).stepgen.00.velocity-cmd
net x-pos-fb <= [HMOT](CARD0).stepgen.00.position-fb
net x-pos-fb => joint.0.motor-pos-fb
net x-enable <= joint.0.amp-enable-out
net x-enable => [HMOT](CARD0).stepgen.00.enable
# ---setup home / limit switch signals---
net home-x => joint.0.home-sw-in
net min-x => joint.0.neg-lim-sw-in
net max-x => joint.0.pos-lim-sw-in
# AXIS Z JOINT 1
setp pid.z.Pgain [JOINT_1]P
setp pid.z.Igain [JOINT_1]I
setp pid.z.Dgain [JOINT_1]D
setp pid.z.bias [JOINT_1]BIAS
setp pid.z.FF0 [JOINT_1]FF0
setp pid.z.FF1 [JOINT_1]FF1
setp pid.z.FF2 [JOINT_1]FF2
setp pid.z.deadband [JOINT_1]DEADBAND
setp pid.z.maxoutput [JOINT_1]MAX_OUTPUT
setp pid.z.error-previous-target true
setp pid.z.maxerror 0.012700
net z-index-enable <=> pid.z.index-enable
net z-enable => pid.z.enable
net z-pos-cmd => pid.z.command
net z-pos-fb => pid.z.feedback
net z-output <= pid.z.output
setp [HMOT](CARD0).stepgen.01.dirsetup [JOINT_1]DIRSETUP
setp [HMOT](CARD0).stepgen.01.dirhold [JOINT_1]DIRHOLD
setp [HMOT](CARD0).stepgen.01.steplen [JOINT_1]STEPLEN
setp [HMOT](CARD0).stepgen.01.stepspace [JOINT_1]STEPSPACE
setp [HMOT](CARD0).stepgen.01.position-scale [JOINT_1]STEP_SCALE
setp [HMOT](CARD0).stepgen.01.step_type 0
setp [HMOT](CARD0).stepgen.01.control-type 1
setp [HMOT](CARD0).stepgen.01.maxaccel [JOINT_1]STEPGEN_MAXACCEL
setp [HMOT](CARD0).stepgen.01.maxvel [JOINT_1]STEPGEN_MAXVEL
net z-pos-cmd <= joint.1.motor-pos-cmd
net z-vel-cmd <= joint.1.vel-cmd
net z-output <= [HMOT](CARD0).stepgen.01.velocity-cmd
net z-pos-fb <= [HMOT](CARD0).stepgen.01.position-fb
net z-pos-fb => joint.1.motor-pos-fb
net z-enable <= joint.1.amp-enable-out
net z-enable => [HMOT](CARD0).stepgen.01.enable
net home-z => joint.1.home-sw-in
net min-z => joint.1.neg-lim-sw-in
net max-z => joint.1.pos-lim-sw-in
# SPINDLE
setp pid.s.Pgain [SPINDLE_0]P
setp pid.s.Igain [SPINDLE_0]I
setp pid.s.Dgain [SPINDLE_0]D
setp pid.s.bias [SPINDLE_0]BIAS
setp pid.s.FF0 [SPINDLE_0]FF0
setp pid.s.FF1 [SPINDLE_0]FF1
setp pid.s.FF2 [SPINDLE_0]FF2
setp pid.s.deadband [SPINDLE_0]DEADBAND
net ratio_select.out pid.s.maxoutput
setp pid.s.error-previous-target true
net spindle-index-enable <=> pid.s.index-enable
net spindle-enable => pid.s.enable
net spindle-vel-cmd-rpm-abs => pid.s.command
net spindle-vel-fb-rpm-abs => pid.s.feedback
net spindle-pid-out pid.s.output => scale.gear.in
net gear-ratio ratio_select.out-f => scale.gear.gain
setp ratio_select.in00 0.000667
setp ratio_select.in01 0.000167
net gear-select-a => ratio_select.sel0
net spindle-output <= scale.gear.out
setp [HMOT](CARD0).encoder.00.counter-mode 0
setp [HMOT](CARD0).encoder.00.filter 1
setp [HMOT](CARD0).encoder.00.index-invert 0
setp [HMOT](CARD0).encoder.00.index-mask 0
setp [HMOT](CARD0).encoder.00.index-mask-invert 0
setp [HMOT](CARD0).encoder.00.scale [SPINDLE_0]ENCODER_SCALE
net spindle-revs <= [HMOT](CARD0).encoder.00.position
net spindle-vel-fb-rps <= [HMOT](CARD0).encoder.00.velocity
net spindle-index-enable <=> [HMOT](CARD0).encoder.00.index-enable
net spindle-vel-cmd-rps <= spindle.0.speed-out-rps
net spindle-vel-cmd-rps-abs <= spindle.0.speed-out-rps-abs
net spindle-vel-cmd-rpm <= spindle.0.speed-out
net spindle-vel-cmd-rpm-abs <= spindle.0.speed-out-abs
net spindle-enable <= spindle.0.on
net spindle-cw <= spindle.0.forward
net spindle-ccw <= spindle.0.reverse
net spindle-brake <= spindle.0.brake
net spindle-revs => spindle.0.revs
net spindle-vel-fb-rps => spindle.0.speed-in
net spindle-index-enable <=> spindle.0.index-enable
sets spindle-at-speed true
# connect miscellaneous signals
# ---HALUI signals---
net axis-select-x halui.axis.x.select
net jog-x-pos halui.axis.x.plus
net jog-x-neg halui.axis.x.minus
net jog-x-analog halui.axis.x.analog
net x-is-homed halui.joint.0.is-homed
net axis-select-z halui.axis.z.select
net jog-z-pos halui.axis.z.plus
net jog-z-neg halui.axis.z.minus
net jog-z-analog halui.axis.z.analog
net z-is-homed halui.joint.1.is-homed
net jog-selected-pos halui.axis.selected.plus
net jog-selected-neg halui.axis.selected.minus
net spindle-manual-cw halui.spindle.0.forward
net spindle-manual-ccw halui.spindle.0.reverse
net spindle-manual-stop halui.spindle.0.stop
net machine-is-on halui.machine.is-on
net jog-speed halui.axis.jog-speed
net MDI-mode halui.mode.is-mdi
# ---coolant signals---
net coolant-mist <= iocontrol.0.coolant-mist
net coolant-flood <= iocontrol.0.coolant-flood
# ---probe signal---
net probe-in => motion.probe-input
# ---motion control signals---
net in-position <= motion.in-position
net machine-is-enabled <= motion.motion-enabled
# ---digital in / out signals---
net dout-00 <= motion.digital-out-00
# ---estop signals---
net estop-out => iocontrol.0.emc-enable-in
# ---manual tool change signals---
net tool-change-request iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-change-confirmed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
Last edit: 30 May 2021 20:03 by Bassblaster.
30 May 2021 21:11 - 30 May 2021 21:12 #210743
Replied by andypugh on topic Luxturn LTI Lathe Retrofit
The missing link seems to be pid.s.output to pwm.
Somewhere in the [SPINDLE] section try adding:
net spindle-enable [HMOT](CARD0)pwmgen.00.enable
net pwm-dc pid.s.output [HMOT](CARD0)pwmgen.00.value
setp [HMOT](CARD0)pwmgen.00.scale {your max rpm}
Last edit: 30 May 2021 21:12 by andypugh.
- Bassblaster
30 May 2021 21:52 #210750
by Bassblaster
Thanks for the help, that totally worked! Now the old lady is spinning up! I am a total noob, so I appreciate your help a lot!
For now there is one task left, unfortunately, it is propably also the most difficult. The toolchanger.
The toolchanger is a 8-station turret toolchanger, which can freely move in one direction,but in the other direction, there are stops for each tool position, kind of like a ratchet. Currently there is no index switch on the toolchanger, so I might add one, if necessary.
I am planning to utilize one of the mesa cards stepgenerators to drive the stepper motor for the toolchanger.
I think I have to write a macro of sorts to achieve this, if I am right.
Do you have any suggestions/ examples for this case?
30 May 2021 21:55 #210751
Moderators: piasdom
Time to create page: 0.107 seconds
