SoyanPower/Lapond VFD Brake Current
21 Dec 2021 21:14 #229656
by slammers
SoyanPower/Lapond VFD Brake Current was created by slammers
I have a 1.5KW, 220V Soyan Power VFD on my Lathe. I want to add a brake resistor as the spindle will not slow down fast enough for CSS.
I can not find any specs on the maximum braking curren this VFD can provide. Does anyone else use this VFD with a resistor and if so can you give me an idea on resistance and wattage you use?
21 Dec 2021 21:43 #229659
Replied by andypugh on topic SoyanPower/Lapond VFD Brake Current
Not the same VFD, or the same manufacturer, but my HuangYang manual lists a 100 Ohm / 300W resistor for their 1.5kW / 220V inverter.
Moderators: piasdom
Time to create page: 0.072 seconds
