Huyndai hit 15s retrofit
30 Nov 2022 03:01 - 30 Nov 2022 03:04 #258081
by Mr.
Huyndai hit 15s retrofit was created by Mr.
Hey guys. Bought a machine at an online auction and was told it powered up but had a controller card issue. So i figured mabe 1k worth of parts and id have a running machine......
well i was in a hurry to load it up and get it home to find they were pretty dishonest(even talked to the seller) seems they parted the keyboard interface, io stuff, and some other stuff pretty sad but i was working on getting it back togather...
then i found they took the dam hard drive, there goes that idea lol
Well out with the old hitrol in with the new lunixcnc
Im assuming its gunna be slow going so i can figure this all out, ive done a g0704 mill awhile back with mach3 and i know sumin fully functional is gunna be alot more difficult but im willing to learn, hopefully in my yrs my brain hasnt smoothed out completly lol
heres the plan
Lunixcnc
mesa board
Simodrive 611 drives (as long as there still good)
Current siemens servos
heres the plan
Lunixcnc
mesa board
Last edit: 30 Nov 2022 03:04 by Mr.. Reason: Weird format
30 Nov 2022 03:09 - 30 Nov 2022 03:10 #258082
by Mr.
Replied by Mr. on topic Huyndai hit 15s retrofit
Last edit: 30 Nov 2022 03:10 by Mr..
30 Nov 2022 03:16 #258083
by Mr.
Heres the first question.
id like to the the ethernet based card and im pretty sure the 611 drives need along 0-10v so a 7i97 would work perfectly, but there not available atm. is it possible you use a 7i96s or 7i76e with daughter cards? Looking for sumin i can buy sooner than later
Thanks guys
Thanks guys
30 Nov 2022 04:13 #258090
by Henk
Replied by Henk on topic Huyndai hit 15s retrofit
Don't assume that that 611 drives are analog. It depends on the control card that is fitted to them. Only the universal one can be controlled via analog.
The following user(s) said Thank You: Mr.
30 Nov 2022 04:22 #258092
by Mr.
Machine is a 96ish 840c with seimens 611, from what ive been researching theres a good chance they could be, but your right never assume. Ill do some more digging
- Thank you received: 5932
30 Nov 2022 10:01 #258105
Replied by tommylight on topic Huyndai hit 15s retrofit
If the drives are analog, you would need 1 of:
5i25
6i25
7i92
7i96s
And 1 of 7i77
Not sure if there is ready made firmware for 7i96s/7i77.
And first two are not ethernet, but with the current state of chips, see what you can find, probably the easiest combo is 7i96s/7i77 to find.
5i25
6i25
7i92
7i96s
And 1 of 7i77
30 Nov 2022 14:33 #258125
by Mr.
7i77 looks outta stock everywhere aswell bummer lol
30 Nov 2022 15:35 #258135
There are other options for sure, i did not use them so i can not refference numbers, but there should be an analog output daughter card, there are encoder cards, IO cards, etc.
Would gladly have a look and report back if i get a chance, in the meantime, others please chime in.
30 Nov 2022 15:46 #258139
by Mr.
Ive got a lil bit of time still, so hopefully sumin pops up. I have a bunch of other work i can do in the mean time
01 Dec 2022 17:07 #258231
Replied by andypugh on topic Huyndai hit 15s retrofit
Maybe 5i24 + 7i36?
store.mesanet.com/index.php?route=produc...83_85&product_id=298
store.mesanet.com/index.php?route=produc...t_id=366&search=7i36
I use the 6i24 (PCIe version, out of stock) on my lathe, it's probably the most IO pins / $£€ of the Mesa boards. The 6i24 is a PCI card, though, and so would need a PCI (not PCIe) motherboard.
Alternatively, still working with the 50-pin "HD" family of mesa cards, MesaUS has a 7i80HD in stock that would work with the 7i36. (there are also other HD servo interfaces, such as the 7i48 but for a lathe I think that the 7i36 with 4 channels + onboard GPIO is a better bet)
Moderators: piasdom
Time to create page: 0.191 seconds
