HSS indexable inserts , link in post
- smc.collins
- Thank you received: 109
05 Apr 2023 23:28 #268363
by smc.collins
HSS indexable inserts , link in post was created by smc.collins
as some of you do not have the machines to truly leverage carbide tools, nor the need. These popped onto my radar looking for inserts to handle interrupted cutting on cast iron. figured I would share.
www.arwarnerco.com/category-s/149.htm
05 Apr 2023 23:40 #268365
Replied by andypugh on topic HSS indexable inserts , link in post
The 0.15" groovers look interesting, though I am puzzled that the LH as RH ones look identical. I can imagine using those to make lock pins and wafers.
It an interesting indication about issues of scale that the HSS ones cost the same as carbide.
- smc.collins
05 Apr 2023 23:51 #268367
by smc.collins
Replied by smc.collins on topic HSS indexable inserts , link in post
interrupted cuts in hard materials, they tend to kill carbide inserts. also HSS is better for low power machines that aren't very rigid, they are sharper and are easier to use than carbide. Also thin work, small diameter materials that move etc. I thought they were interesting and useful for hobbyist's so I posted them up as a resources. Using standard tool holders is a massive plus.
06 Apr 2023 00:03 #268368
Oh, yes, I see the point entirely. I was just observing that the small production levels of a considerably easier to make part leads to price parity. In some ways I am surprised that they are not more exspensive, than carbide. I am wondering if they are actually made the same way using powder metallurgy, which would potentially make them a special run on the same machines, rather than making them by a completely separate process.
- smc.collins
06 Apr 2023 02:14 #268372
by smc.collins
i called they are made from annealed has and then hardened and honed to size edge, i sent spme mcmn amd a few other common grooving inserts to see if they could make those as I'm working on some thin parts and wanted a hss tool without the hassle.
06 Apr 2023 05:31 #268382
by phillc54
Replied by phillc54 on topic HSS indexable inserts , link in post
I have been using their CCMW inserts for several years on my little Sherline and I am very happy with them.
Moderators: piasdom
Time to create page: 0.075 seconds
