Spindle Encoder for 7 x 14 mini lathe
15 Aug 2023 17:18 #278058
by krigby
Spindle Encoder for 7 x 14 mini lathe was created by krigby
Does anyone have any experience adding a spindle encoder to the Harbor Freight/Vevor/C3 model of 7 x 14 mini lathe?
I have two goals:
1) know the position and of the spindle for operations like threading
2) - next step: control the spindle speed from LinuxCNC.
But for now I want to focus on the spindle encoder,
I thought about replacing the motor with a servo motor with built in encoder, but I am not sure if that is feasible, Although I suspect it is if I added a VFD or something, but I could be totally off base on that one.
Any advice will be greatly appreciated. I can send pictures of the spindle if that helps, and it does seem to have a 4 'contact' hall effect sensor attached to the end of the spindle already. I assume that is how the readout on the lathe knows what the spindle speed is but I haven't dug into that yet.
Thanks,
Kent
I have two goals:
Thanks,
Kent
15 Aug 2023 20:22 #278077
Replied by andypugh on topic Spindle Encoder for 7 x 14 mini lathe
The simplest option would be to belt-drive a commercial encoder from the spindle with a toothed belt in a 1:1 ratio.
It is also fairly straighforward to make an encoder, using a drilled plate and three opto sensors. Or two if you don't plan on using rigid tapping. Or, in fact, just one if using missing-tooth indexing.
On the same theme as that last option, you might want to look at a car crank sensor, as these have space for a nice big through-bore:
The following user(s) said Thank You: jpg
16 Aug 2023 01:06 - 16 Aug 2023 01:23 #278103
by COFHAL
Replied by COFHAL on topic Spindle Encoder for 7 x 14 mini lathe
Last edit: 16 Aug 2023 01:23 by COFHAL.
Moderators: piasdom
Time to create page: 0.174 seconds
