Anilam lathemate
08 Nov 2023 03:00 #284833
by Jeffm1
Anilam lathemate was created by Jeffm1
I have an anilam lathemate lathe it has a westamp mt 233 motor driving the z axis this motor says that it is 26 lb/in 140 max volts and 47 pulse amps. I am thinking about replacing this with an AC servo, what wattage of AC servo should be equivalent to this motor.
- Online
- Thank you received: 5951
08 Nov 2023 11:18 #284857
Replied by tommylight on topic Anilam lathemate
Voltage is not very important, current is, so check manuals for current limiting, all drives should have it, but on some it is very hard to program.
Is it a brushed or brushless motor?
The following user(s) said Thank You: Jeffm1
08 Nov 2023 13:27 #284865
Replied by andypugh on topic Anilam lathemate
I would size the motor on rated torque, not on power.
So look for a servo with a similar rated torque.
24 Mar 2024 02:58 #296609
by COFHAL
Replied by COFHAL on topic Anilam lathemate
Does your lathe have ATC?
Moderators: piasdom
Time to create page: 0.143 seconds
