What driver board to use?
28 May 2010 03:03 #3029
by aike
What driver board to use? was created by aike
Hi!
I want to replace existing CNC from Sodick (www.sodick.com), based on Windows95 and PMAC2-PC ISA as driver board from DeltaTau to
EMC + some driver board. The CNC verical center has name Sodick MC450 (vintage 1999).
I have 3 axes + 1 spindel + arm + turret for 20 tools. Hence 6 (six) servo drivers are using now.
What board I need to use? I don't want to use PMAC2 from DeltaTau. Is ther any more cheaper board?
DeltaTau has G compilator in its own build in memory. EMC software use its own G-code compiler.
The main problem - connect 6 servo drivers + number of I/O to interconnect with tool's turret.
Any advices?
Any advices?
28 May 2010 11:06 #3035
by BigJohnT
Replied by BigJohnT on topic Re:What driver board to use?
Do your drives take velocity inputs +-10vdc? Do your servos have encoder feedback?
28 May 2010 13:38 #3036
by aike
Replied by aike on topic Re:What driver board to use?
Yes, I use standart servo motor/servo driver with +-10V ADC
28 May 2010 13:43 #3037
by aike
We also can use frequency-pulse driver control (like step motor) with encoder feedback.
Our servo driver can operate in both mode (+-10V and Freq/Pulse control).
The number of pulses per one round may be programmed from 200 till 4000 steps.
28 May 2010 14:30 #3039
Replied by PCW on topic Re:What driver board to use?
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?EMC2_Supported_Hardware
www.mesanet.com
pico-systems.com
www.vitalsystem.com
All make EMC2 compatible analog servo interface cards
www.mesanet.com
pico-systems.com
make EMC compatible hardware step generator cards
www.mesanet.com
pico-systems.com
www.vitalsystem.com
www.mesanet.com
pico-systems.com
Time to create page: 0.230 seconds
