Field Power / VIN / 5V / 24V
13 Feb 2016 18:12 #70073
by Clive S
Replied by Clive S on topic 5i25 7i76 Question
Thanks Peter for the note. I have looked back and don't seem to see where W3 was mentionedNote, W2 sets connector P3's 5V power option, not W3
13 Feb 2016 18:27 #70075
Replied by PCW on topic 5i25 7i76 Question
its in the 5I25 picture
13 Feb 2016 18:30 #70077
by Clive S
Well spotted its good to know that we are being looked on from aboveits in the 5I25 picture
13 Feb 2016 20:04 #70083
by BigJohnT
YIKES!, Thanks for pointing that out Peter.
JT
Replied by BigJohnT on topic 5i25 7i76 Question
JT
15 Feb 2016 08:56 #70155
by Amedee
Replied by Amedee on topic 5i25 7i76 Question
I just bought the same kit, so here is a bit of feedback...
Yes, one think funny though, is that by default the 7i76 is set to source 5v from the PCI card, but the 6i25 is set to not send it to the break-out board
So whatever your choice is, you need to change a jumper.
Ok I purchased these two cards together so I assume that it has been flashed with the correct firmware.
The 6i25 is just a 5i25 with a PCIe to PCI bridge, so for LinuxCNC it only sees a 5i35 and this is OK.I am only using one 7i76 but I don't see in the Pncconfig the option to use just one card it seems to say 5i35 x 2 7i76 would this be ok for an initial setup?
- Thank you received: 1369
15 Feb 2016 13:38 #70160
Replied by Todd Zuercher on topic 5i25 7i76 Question
It would make sense to have the default jumper positions on the 5i25/6i25 be in the ground position rather than the 5v source. It is the safest way to have it wrong.
15 Feb 2016 13:49 - 15 Feb 2016 13:51 #70161
by Amedee
Yes, and it is the case
(My remark was that he 7i76 on the contrary expects by default to get 5v from the [56]i25 -- so whatever your choice is you will have to change the one or the other)
Last edit: 15 Feb 2016 13:51 by Amedee.
15 Feb 2016 14:51 #70163
by BigJohnT
Good to know the 6i25 is not set for 5v to P3 out of the box. When I ship them I'll make sure they are set correctly and the label lists the jumper positions in addition to the loaded firmware.
JT
JT
15 Feb 2016 15:07 #70164
by Clive S
Ok so on conclusion for us newbies what are the recommended jumper settings for the 5i25 with 7i76 using field power at 24V (ie do you use the 5V pwr from the 5i25) ? As reading all the posts it is ambiguous to me.
15 Feb 2016 15:15 - 15 Feb 2016 15:23 #70165
by Amedee
You are mixing things...
24V (or whatever your decide) is for the field power.
But you also need power for the step/dir signals to your drives, in principle 5V. So the choice is between:
I use 24V for field, and take the 5V from my 6i25, to avoid an additional PSU
- Getting the 5V from your computer (changing the 6i25 jumper to provide 5V)
- Providing yourself 5V from another power source directly to the 7i76 (changing the 7i76 jumper to isolate the 5V)
Last edit: 15 Feb 2016 15:23 by Amedee.
Time to create page: 0.096 seconds
