Field Power / VIN / 5V / 24V
I'm also setting up my 7i76 board and hope it's OK to post a question here, because we're on the same topic. When choosing a 24v power supply for the I/O is there any particular spec or design I should look for? Like for example, should I look for a regulated power supply, what should be minimum current rating, how much voltage ripple is acceptable? My apology if this has been asked before but I don't think the manual talks about it...
- Tim
I tend you use this type of course they can be got in various amps ratingsWhen choosing a 24v power supply for the I/O is there any particular spec or design I should look for? Like for example, should I look for a regulated power supply, what should be minimum current rating, how much voltage ripple is acceptable?
www.aliexpress.com/item/60W-output-24VDC...40010308.4.30.jFbkSB
- Thank you received: 5944
when you say "original phone chargers" can you explain please
I take it you mean non usb type chargers
USB ones, but original Samsung ones, not ebay or whatever cheap crappy ones, those can do a lot of damage.hey tom I know this is a old post...
- garrettmin
7I76E HAS DIFFERENT VOLTAGE THAN 7I76 @ TB3
7I76E TB3 @ PIN 21,22 = UNREG LOGIC PWR+ IN
7I76D TB3 @ PIN 21,22 = +5V
- 5V ONLY
- NOT EQUAL TO
- 24V UNREG LOGIC PWR+ IN
- NOT EQUAL TO
7i76E is not a 7i76 or 7i76D when powering is concerned (they are the same for everything else). 7i76E has the option of power from two 12V or 24V terminals leaving the 5V unused, but it looses isolation i think, so double check this.
- garrettmin
You can Series Connect these into 24V,36V, etc...
www.rcgroups.com/forums/showthread.php?1...-Supply-Part1/page32
