Lathe controller
03 Feb 2017 00:23 #87170
Replied by andypugh on topic Lathe controller
The 7i76 can step at 10MHz I think. Any other external step generator will be about the same.
Even with a latency of 500µS. (typically you would need 25µS latency to do 50kHz with software stepping)
03 Feb 2017 00:34 #87171
Replied by PCW on topic Lathe controller
Yes ,~10 MHz is the limit on the 7I76E
The latency is not very important as long as you can access the card every millisecond
Step rate settability varies proportionally with the step rate but is about 1 PPM at 50 Hz
( rate generator is 32 bit accumulator running at 100 MHz )
03 Feb 2017 00:36 #87172
by kor
Replied by kor on topic Lathe controller
Sry andy your answer confuses me.
if the latency is 0.5mS I still have 10Mhz ?
03 Feb 2017 00:36 #87173
Yes
03 Feb 2017 00:38 - 03 Feb 2017 00:39 #87174
by kor
So accessing once every mSecond shouldn't be a problem with any decent PC guess.
Last edit: 03 Feb 2017 00:39 by kor. Reason: typo made the sense of the post change
03 Feb 2017 01:00 #87175
Most PCs will work (Though very slow PCs like Atom D525s are marginal with Preempt-RT)
For fanless systems, Intel J1800, J1900, N3150 based PCs are good choices as are the AMD A4 series
03 Feb 2017 10:40 - 03 Feb 2017 10:41 #87200
Replied by rodw on topic Lathe controller
I have a Mesa 7i76e card and am driving it with a Gigabyte Brix J1900 Ultra Small Form Factor PC that fits in the palm of your hand. Latency is quite poor but still OK according to Mesa. Here's what I am achieving...
I am using Longs Motor DM542A Stepper controllers set to 25x Microsteppping. So on my 200 ppr steppers, thats 5000 pulses per rev. I can run these reliably at 650 rpm. So lets do the maths:
200 ppr x 25 microsteps x 650 rpm = 3,250,000 pulses per minute (or 3.25 mHz). Your 120kHz will be a walk in the park.
What I achieved is still well under the published maximum step frequency. I think the limiting factor in my setup was the step lengths (which meant there is a limit to the number of pulses you can fit in a second). After settling on these specs, I reduced the step length from 2500 usec to 1500 usec but never bothered to see if I could push it further afterwards. (going below 2500 usec is not recommended) Anyway, if nothing else, I proved that there are other physical limits that come into play well before the 7i76e reaches its maximum step frequency.
Last edit: 03 Feb 2017 10:41 by rodw.
- Thank you received: 5928
03 Feb 2017 12:26 #87205
Just a minor error,
3.250.000 pulses per minute divede by 60 equals........not 3.25 MHz.
Hz is rate per second, not minute.
Replied by tommylight on topic Lathe controller
Just a minor error,
- Thank you received: 1369
03 Feb 2017 12:43 #87207
Replied by Todd Zuercher on topic Lathe controller
Before you commit to any certain interface hardware, you should consider, and determine the hardware you will be using with the machine, because some motor drives are better controlled with certain hardware. Is this lathe a conversion of a dead CNC or is it automation of a manual machine. If it is the resurrection of a machine that already has motors, it is often best to reuse the old servos. Which, unlike Mach, Linuxcnc can usually easily control with the right hardware.
03 Feb 2017 15:04 #87214
by kor
It is neither. It is a new build one. I just purchased the spindle and motor bed mechanics and electrics will be made by me. So i am free to use whatever i like and can afford.
Time to create page: 0.161 seconds
