Scaling THCAD-10 input
  • rodw
  • rodw's Avatar Topic Author
  • Platinum Member
  • Platinum Member
11 Mar 2017 02:11 #89392 by rodw
Scaling THCAD-10 input was created by rodw
I want to use the THCAD-10 with a 20 volt input range.
PCW has already told me my maths sucked and I need to use 100k resistors.
What is not clear is if resistors are required on both the Analog In + and Analog In -
The manual says resistors in one place and resistor in another. Can somebody please clarify this please?
11 Mar 2017 15:24 #89421 by PCW
Replied by PCW on topic Scaling THCAD-10 input
In your case its not too important where the resistor(s) go.
As long as you add a total of 100K series resistance to the inputs
you will have a 20V full scale range.
Moderators: PCWjmelson
Time to create page: 0.191 seconds
