intermittant timeouts from hm2_sserial_waitfor
13 Mar 2017 15:17 - 13 Mar 2017 15:18 #89528
by jCandlish
intermittant timeouts from hm2_sserial_waitfor was created by jCandlish
I am seeing infrequent but persistent timeouts from hm2_sserial_waitfor
Sometimes the timeout comes from the 7i73 on channel 1.
What could be the cause of this timeout?
Can I relax the timeout interval?
My ping latency averages about 0.25ms
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 10.100.10.100: Hardware address: 00:60:1b:11:00:92
hm2_eth: discovered 7I80HD-16
hm2/hm2_7i80.0: Smart Serial Firmware Version 43
Board hm2_7i80.0.7i84.0.0 Hardware Mode 0 = standard
Board hm2_7i80.0.7i84.0.0 Software Mode 0 = input_output
Board hm2_7i80.0.7i84.0.0 Software Mode 1 = io_analog_fieldvoltage
Board hm2_7i80.0.7i84.0.0 Software Mode 2 = io_encoder_analog
hm2/hm2_7i80.0: hm2_sserial_waitfor: Timeout (25mS) waiting for addr 5a00 &mask ffffffff val 0
hm2/hm2_7i80.0: DATA addr 5b00 after timeout: 0
hm2/hm2_7i80.0: Timeout during do-it in sserial_get_bytes
hm2/hm2_7i80.0: Failed to read/setup the globals on hm2_7i80.0.7i84.0.0
hm2/hm2_7i80.0: Remote setup failure on instance 0
hm2/hm2_7i80.0: failed to parse Module Descriptor 3
board fails HM2 registration
latheoperator@125cnc:~/linuxcnc$ ping 10.100.10.100
PING 10.100.10.100 (10.100.10.100) 56(84) bytes of data.
64 bytes from 10.100.10.100: icmp_seq=1 ttl=64 time=0.245 ms
64 bytes from 10.100.10.100: icmp_seq=2 ttl=64 time=0.221 ms
64 bytes from 10.100.10.100: icmp_seq=3 ttl=64 time=0.267 ms
64 bytes from 10.100.10.100: icmp_seq=4 ttl=64 time=0.268 ms
64 bytes from 10.100.10.100: icmp_seq=5 ttl=64 time=0.227 ms
64 bytes from 10.100.10.100: icmp_seq=6 ttl=64 time=0.267 ms
64 bytes from 10.100.10.100: icmp_seq=7 ttl=64 time=0.274 ms
64 bytes from 10.100.10.100: icmp_seq=8 ttl=64 time=0.269 ms
64 bytes from 10.100.10.100: icmp_seq=9 ttl=64 time=0.227 ms
64 bytes from 10.100.10.100: icmp_seq=10 ttl=64 time=0.250 ms
64 bytes from 10.100.10.100: icmp_seq=11 ttl=64 time=0.230 ms
^C
latheoperator@125cnc:~/linuxcnc$ mesaflash --verbose --device 7i80 --addr 10.100.10.100 --sserial
SSLBP port 0:
SSLBP Version: 1.43
SSLBP Channels: 2
SSLBP Baud Rate: 2500000
interface type: 12
interface width: 8
SSLBP Channel Start: 112
SSLBP Channel Stride: 50
SSLBP Processor Type: d8
SSLBP Clock: 100 MHz
sserial device at channel 0: 7I84
SwRevision = 15
HwRevision = 1
NVBaudRate = 2.5Mb
NVUnitNumber = 0x180000F3
NVWatchDogTimeout = 50ms
EncMode0 = ffff [16 bits UNSIGNED IN | UNIT: None | RANGE: 0.00 - 0.00 | ADDR: 0998]
EncMode1 = ffff [16 bits UNSIGNED IN | UNIT: None | RANGE: 0.00 - 0.00 | ADDR: 099A]
NVEncMode0 = 0 [16 bits NV UNSIGNED IN | UNIT: None | RANGE: 0.00 - 0.00 | ADDR: 0066]
NVEncMode1 = 0 [16 bits NV UNSIGNED IN | UNIT: None | RANGE: 0.00 - 0.00 | ADDR: 0068]
SOFTWARE MODE Input_Output [index 00]
SOFTWARE MODE IO_Analog_FieldVoltage [index 01]
SOFTWARE MODE IO_Encoder_Analog [index 02]
sserial device at channel 1: 7I73
Contrast = ffff [16 bits UNSIGNED OUT | UNIT: None | RANGE: 0.00 - 0.00 | ADDR: 09C6]
EncMode0 = ffff [16 bits UNSIGNED OUT | UNIT: None | RANGE: 0.00 - 0.00 | ADDR: 0998]
EncMode1 = ffff [16 bits UNSIGNED OUT | UNIT: None | RANGE: 0.00 - 0.00 | ADDR: 099A]
EncMode2 = ffff [16 bits UNSIGNED OUT | UNIT: None | RANGE: 0.00 - 0.00 | ADDR: 099C]
EncMode3 = ffff [16 bits UNSIGNED OUT | UNIT: None | RANGE: 0.00 - 0.00 | ADDR: 099E]
SwRevision = 14
HwRevision = 1
KeyMode = ffff [16 bits UNSIGNED OUT | UNIT: None | RANGE: 0.00 - 0.00 | ADDR: 09DE]
NVContrast = 2710 [16 bits NV UNSIGNED OUT | UNIT: None | RANGE: 0.00 - 0.00 | ADDR: 0044]
NVEncMode0 = 0 [16 bits NV UNSIGNED OUT | UNIT: None | RANGE: 0.00 - 0.00 | ADDR: 003A]
NVEncMode1 = 0 [16 bits NV UNSIGNED OUT | UNIT: None | RANGE: 0.00 - 0.00 | ADDR: 003C]
NVEncMode2 = 0 [16 bits NV UNSIGNED OUT | UNIT: None | RANGE: 0.00 - 0.00 | ADDR: 003E]
NVEncMode3 = 0 [16 bits NV UNSIGNED OUT | UNIT: None | RANGE: 0.00 - 0.00 | ADDR: 0040]
NVDispMode = 414 [16 bits NV UNSIGNED OUT | UNIT: None | RANGE: 0.00 - 0.00 | ADDR: 0006]
NVKeyTimer = 1e [16 bits NV UNSIGNED OUT | UNIT: None | RANGE: 0.00 - 0.00 | ADDR: 0046]
NVAnalogFilter = 8000 [16 bits NV UNSIGNED OUT | UNIT: None | RANGE: 0.00 - 0.00 | ADDR: 0042]
NVBaudRate = 2.5Mb
NVUnitNumber = 0x130000E2
SOFTWARE MODE InputOutputEncoder [index 00]
SOFTWARE MODE InputOutputEncoderAnalog [index 01]
SOFTWARE MODE InputOutputEncoderAnalog [index 02]
SOFTWARE MODE InputOutputEncoderDisplay [index 00]
SOFTWARE MODE InputOutputEncoderAnalogDisplay [index 01]
SOFTWARE MODE InputOutputEncoderAnalogWideDisplay [index 02]
SOFTWARE MODE InputOutputEncoderKeycode4by8 [index 00]
SOFTWARE MODE InputOutputEncoderAnalogKeycode4by8 [index 01]
SOFTWARE MODE InputOutputEncoderAnalogKeycode4by8 [index 02]
SOFTWARE MODE InputOutputEncoderDisplayKeycode4by8 [index 00]
SOFTWARE MODE InputOutputEncoderAnalogDisplayKeyCode4by8 [index 01]
SOFTWARE MODE InputOutputEncoderAnalogWideDisplayKeyCode4by8 [index 02]
SOFTWARE MODE InputOutputEncoderKeycode8by8 [index 00]
SOFTWARE MODE InputOutputEncoderAnalogKeyCode8by8 [index 01]
SOFTWARE MODE InputOutputEncoderAnalogKeyCode8by8 [index 02]
SOFTWARE MODE InputOutputEncoderDisplayKeycode8by8 [index 00]
SOFTWARE MODE InputOutputEncoderAnalogDisplayKeyCode8by8 [index 01]
SOFTWARE MODE InputOutputEncoderAnalogWideDisplayKeyCode8by8 [index 02]
Last edit: 13 Mar 2017 15:18 by jCandlish.
13 Mar 2017 16:19 #89530
Replied by PCW on topic intermittant timeouts from hm2_sserial_waitfor
Looks like a power or signal integrity issue of some kind
( if the remote does not answer in ~20 usec its not going to )
Time to create page: 0.252 seconds
