hm2dpll, pin hm2_XiXX.N.encoder.MM.timer-num does not exist.
30 Mar 2017 06:20 #90548
by jCandlish
How does one configure hm2dpll for encoders?
This hal fragment is throwing the error:
Is this maybe not working for muxed encoders?
# phase lock loop
setp hm2_7i80.0.dpll.01.timer-us -100
setp hm2_7i80.0.stepgen.timer-number 1
setp hm2_7i80.0.encoder.08.timer-num 1
parameter or pin 'hm2_7i80.0.encoder.08.timer-num' not found
30 Mar 2017 13:19 - 30 Mar 2017 13:29 #90564
Replied by PCW on topic hm2dpll, pin hm2_XiXX.N.encoder.MM.timer-num does not exist.
What configuration are you using?
( and how many encoders have you enabled )
Last edit: 30 Mar 2017 13:29 by PCW.
30 Mar 2017 14:36 - 30 Mar 2017 14:43 #90565
by jCandlish
Replied by jCandlish on topic hm2dpll, pin hm2_XiXX.N.encoder.MM.timer-num does not exist.
loadrt threads name1=servo-thread period1=1000000
loadrt pid num_chan=1
loadrt hostmot2
loadrt hm2_eth board_ip="10.100.10.100" config="firmware=hm2/7i80hd16/5xST_3xENC_2xSS_6xSV.BIT num_encoders=12 num_pwmgens=0 num_stepgens=5 sserial_port_0=00000000"
setp hm2_7i80.0.watchdog.timeout_ns 10000000
# phase lock loop
#setp hm2_7i80.0.encoder.08.timer-num 1
#setp hm2_7i80.0.encoder.10.timer-num 1
latheoperator@125cnc:~/linuxcnc/tuning$ halrun
halcmd:
halcmd: loadrt hostmot2
Note: Using POSIX realtime
halcmd: loadrt hm2_eth board_ip="10.100.10.100" config="firmware=hm2/7i80hd16/5xST_3xENC_2xSS_6xSV.BIT num_encoders=12 num_pwmgens=0 num_stepgens=5 sserial_port_0=00000000"
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 10.100.10.100: Hardware address: 00:60:1b:11:00:92
hm2_eth: discovered 7I80HD-16
hm2/hm2_7i80.0: Smart Serial Firmware Version 43
Board hm2_7i80.0.7i84.0.0 Hardware Mode 0 = standard
Board hm2_7i80.0.7i84.0.0 Software Mode 0 = input_output
Board hm2_7i80.0.7i84.0.0 Software Mode 1 = io_analog_fieldvoltage
Board hm2_7i80.0.7i84.0.0 Software Mode 2 = io_encoder_analog
Board hm2_7i80.0.7i73.0.1 Hardware Mode 0 = nokeyboardnodisplay
Board hm2_7i80.0.7i73.0.1 Software Mode 0 = inputoutputencoder
Board hm2_7i80.0.7i73.0.1 Software Mode 1 = inputoutputencoderanalog
Board hm2_7i80.0.7i73.0.1 Software Mode 2 = inputoutputencoderanalog
Board hm2_7i80.0.7i73.0.1 Hardware Mode 1 = nokeyboarddisplay
Board hm2_7i80.0.7i73.0.1 Software Mode 0 = inputoutputencoderdisplay
Board hm2_7i80.0.7i73.0.1 Software Mode 1 = inputoutputencoderanalogdisplay
Board hm2_7i80.0.7i73.0.1 Software Mode 2 = inputoutputencoderanalogwidedisplay
Board hm2_7i80.0.7i73.0.1 Hardware Mode 2 = keyboard4by8nodisplay
Board hm2_7i80.0.7i73.0.1 Software Mode 0 = inputoutputencoderkeycode4by8
Board hm2_7i80.0.7i73.0.1 Software Mode 1 = inputoutputencoderanalogkeycode4by8
Board hm2_7i80.0.7i73.0.1 Software Mode 2 = inputoutputencoderanalogkeycode4by8
Board hm2_7i80.0.7i73.0.1 Hardware Mode 3 = keyboard4by8display
Board hm2_7i80.0.7i73.0.1 Software Mode 0 = inputoutputencoderdisplaykeycode4by8
Board hm2_7i80.0.7i73.0.1 Software Mode 1 = inputoutputencoderanalogdisplaykeycode4by8
Board hm2_7i80.0.7i73.0.1 Software Mode 2 = inputoutputencoderanalogwidedisplaykeycode4by8
Board hm2_7i80.0.7i73.0.1 Hardware Mode 4 = keyboard8by8nodisplay
Board hm2_7i80.0.7i73.0.1 Software Mode 0 = inputoutputencoderkeycode8by8
Board hm2_7i80.0.7i73.0.1 Software Mode 1 = inputoutputencoderanalogkeycode8by8
Board hm2_7i80.0.7i73.0.1 Software Mode 2 = inputoutputencoderanalogkeycode8by8
Board hm2_7i80.0.7i73.0.1 Hardware Mode 5 = keyboard8by8display
Board hm2_7i80.0.7i73.0.1 Software Mode 0 = inputoutputencoderdisplaykeycode8by8
Board hm2_7i80.0.7i73.0.1 Software Mode 1 = inputoutputencoderanalogdisplaykeycode8by8
Board hm2_7i80.0.7i73.0.1 Software Mode 2 = inputoutputencoderanalogwidedisplaykeycode8by8
hm2/hm2_7i80.0: 72 I/O Pins used:
hm2/hm2_7i80.0: IO Pin 000 (P1-01): IOPort
hm2/hm2_7i80.0: IO Pin 001 (P1-03): Muxed Encoder #0, pin Muxed A (Input)
hm2/hm2_7i80.0: IO Pin 002 (P1-05): Muxed Encoder #0, pin Muxed B (Input)
hm2/hm2_7i80.0: IO Pin 003 (P1-07): Muxed Encoder #0, pin Muxed Index (Input)
hm2/hm2_7i80.0: IO Pin 004 (P1-09): Muxed Encoder #1, pin Muxed A (Input)
hm2/hm2_7i80.0: IO Pin 005 (P1-11): Muxed Encoder #1, pin Muxed B (Input)
hm2/hm2_7i80.0: IO Pin 006 (P1-13): Muxed Encoder #1, pin Muxed Index (Input)
hm2/hm2_7i80.0: IO Pin 007 (P1-15): Muxed Encoder #2, pin Muxed A (Input)
hm2/hm2_7i80.0: IO Pin 008 (P1-17): Muxed Encoder #2, pin Muxed B (Input)
hm2/hm2_7i80.0: IO Pin 009 (P1-19): Muxed Encoder #2, pin Muxed Index (Input)
hm2/hm2_7i80.0: IO Pin 010 (P1-21): Muxed Encoder Select #0, pin Mux Select 0 (Output)
hm2/hm2_7i80.0: IO Pin 011 (P1-23): IOPort
hm2/hm2_7i80.0: IO Pin 012 (P1-25): IOPort
hm2/hm2_7i80.0: IO Pin 013 (P1-27): IOPort
hm2/hm2_7i80.0: IO Pin 014 (P1-29): IOPort
hm2/hm2_7i80.0: IO Pin 015 (P1-31): IOPort
hm2/hm2_7i80.0: IO Pin 016 (P1-33): IOPort
hm2/hm2_7i80.0: IO Pin 017 (P1-35): IOPort
hm2/hm2_7i80.0: IO Pin 018 (P1-37): IOPort
hm2/hm2_7i80.0: IO Pin 019 (P1-39): IOPort
hm2/hm2_7i80.0: IO Pin 020 (P1-41): IOPort
hm2/hm2_7i80.0: IO Pin 021 (P1-43): IOPort
hm2/hm2_7i80.0: IO Pin 022 (P1-45): IOPort
hm2/hm2_7i80.0: IO Pin 023 (P1-47): IOPort
hm2/hm2_7i80.0: IO Pin 024 (P2-01): StepGen #1, pin Step (Output)
hm2/hm2_7i80.0: IO Pin 025 (P2-03): StepGen #1, pin Direction (Output)
hm2/hm2_7i80.0: IO Pin 026 (P2-05): StepGen #2, pin Step (Output)
hm2/hm2_7i80.0: IO Pin 027 (P2-07): StepGen #2, pin Direction (Output)
hm2/hm2_7i80.0: IO Pin 028 (P2-09): Smart Serial Interface #0, pin RxData0 (Input)
hm2/hm2_7i80.0: IO Pin 029 (P2-11): Muxed Encoder #4, pin Muxed A (Input)
hm2/hm2_7i80.0: IO Pin 030 (P2-13): Smart Serial Interface #0, pin RxData1 (Input)
hm2/hm2_7i80.0: IO Pin 031 (P2-15): Muxed Encoder #4, pin Muxed B (Input)
hm2/hm2_7i80.0: IO Pin 032 (P2-17): IOPort
hm2/hm2_7i80.0: IO Pin 033 (P2-19): Muxed Encoder #4, pin Muxed Index (Input)
hm2/hm2_7i80.0: IO Pin 034 (P2-21): Muxed Encoder #3, pin Muxed A (Input)
hm2/hm2_7i80.0: IO Pin 035 (P2-23): Muxed Encoder #5, pin Muxed A (Input)
hm2/hm2_7i80.0: IO Pin 036 (P2-25): Muxed Encoder #3, pin Muxed B (Input)
hm2/hm2_7i80.0: IO Pin 037 (P2-27): Muxed Encoder #5, pin Muxed B (Input)
hm2/hm2_7i80.0: IO Pin 038 (P2-29): Muxed Encoder #3, pin Muxed Index (Input)
hm2/hm2_7i80.0: IO Pin 039 (P2-31): Muxed Encoder #5, pin Muxed Index (Input)
hm2/hm2_7i80.0: IO Pin 040 (P2-33): StepGen #3, pin Step (Output)
hm2/hm2_7i80.0: IO Pin 041 (P2-35): StepGen #3, pin Direction (Output)
hm2/hm2_7i80.0: IO Pin 042 (P2-37): StepGen #4, pin Step (Output)
hm2/hm2_7i80.0: IO Pin 043 (P2-39): StepGen #4, pin Direction (Output)
hm2/hm2_7i80.0: IO Pin 044 (P2-41): Smart Serial Interface #0, pin TxData0 (Output)
hm2/hm2_7i80.0: IO Pin 045 (P2-43): Smart Serial Interface #0, pin TxData1 (Output)
hm2/hm2_7i80.0: IO Pin 046 (P2-45): StepGen #0, pin Step (Output)
hm2/hm2_7i80.0: IO Pin 047 (P2-47): StepGen #0, pin Direction (Output)
hm2/hm2_7i80.0: IO Pin 048 (P3-01): IOPort
hm2/hm2_7i80.0: IO Pin 049 (P3-03): IOPort
hm2/hm2_7i80.0: IO Pin 050 (P3-05): IOPort
hm2/hm2_7i80.0: IO Pin 051 (P3-07): IOPort
hm2/hm2_7i80.0: IO Pin 052 (P3-09): IOPort
hm2/hm2_7i80.0: IO Pin 053 (P3-11): IOPort
hm2/hm2_7i80.0: IO Pin 054 (P3-13): IOPort
hm2/hm2_7i80.0: IO Pin 055 (P3-15): IOPort
hm2/hm2_7i80.0: IO Pin 056 (P3-17): IOPort
hm2/hm2_7i80.0: IO Pin 057 (P3-19): IOPort
hm2/hm2_7i80.0: IO Pin 058 (P3-21): IOPort
hm2/hm2_7i80.0: IO Pin 059 (P3-23): IOPort
hm2/hm2_7i80.0: IO Pin 060 (P3-25): IOPort
hm2/hm2_7i80.0: IO Pin 061 (P3-27): IOPort
hm2/hm2_7i80.0: IO Pin 062 (P3-29): IOPort
hm2/hm2_7i80.0: IO Pin 063 (P3-31): IOPort
hm2/hm2_7i80.0: IO Pin 064 (P3-33): IOPort
hm2/hm2_7i80.0: IO Pin 065 (P3-35): IOPort
hm2/hm2_7i80.0: IO Pin 066 (P3-37): IOPort
hm2/hm2_7i80.0: IO Pin 067 (P3-39): IOPort
hm2/hm2_7i80.0: IO Pin 068 (P3-41): IOPort
hm2/hm2_7i80.0: IO Pin 069 (P3-43): IOPort
hm2/hm2_7i80.0: IO Pin 070 (P3-45): IOPort
hm2/hm2_7i80.0: IO Pin 071 (P3-47): IOPort
hm2/hm2_7i80.0: registered
halcmd:
loadrt hostmot2
# phase lock loop
halcmd:
halcmd:
Last edit: 30 Mar 2017 14:43 by jCandlish. Reason: added
30 Mar 2017 14:54 - 30 Mar 2017 15:46 #90566
OK there does seem to be a bug in the encoder DPLL setup
I think its possibly a firmware bug, I will look into it
Note that the proper pin would be:
hm2_7i80.0.encoder.timer-number
EDIT:
it looks like most 7i80 bitfiles were made before encoder timestamps were added to the firmware
so they likely need to be built from source to get encoder timestamps working
pcw@pcw-G41M-Combo:~/linuxcnc/configs$ halcmd show pin hm2_7i76e.0.encoder.timer-number
Component Pins:
Owner Type Dir Value Name
23 s32 IN -1 hm2_7i76e.0.encoder.timer-number
(I had to rebuild the bitfile to get this)
EDIT:
Component Pins:
Last edit: 30 Mar 2017 15:46 by PCW.
The following user(s) said Thank You: jCandlish
30 Mar 2017 16:00 #90575
by jCandlish
30 Mar 2017 16:03 #90576
Thats at least a year or two out of date
i would fetch the source from Mesa and re-build
31 Mar 2017 05:27 #90626
by jCandlish
How?
How?
31 Mar 2017 13:32 #90641
Download the 7i80.zip file from Mesa
The complete hm2 source is in configs/hostmot2/source
01 Apr 2017 06:00 - 01 Apr 2017 06:05 #90677
by jCandlish
Hmm...
Somehow the zipfile is incomplete.
Replacing the 'src' directory of the git clone (where there is a makefile for building a debian package) with the 'configs/hostmot2/source' directory from 7i80.zip ends with:
I am at a loss to know how to correctly modify the makefile containing:
Which new vhd file takes the place of the missing d8o8.vhd ?
/usr/bin/make -j --jobserver-fds=3,4
make[1]: Entering directory '/home/installer/Dev/hostmot2-from-github/hostmot2-firmware'
scripts/firmwares.py firmwares.txt > fw/firmwares.mk.tmp
mv -f fw/firmwares.mk.tmp fw/firmwares.mk
make[1]: *** No rule to make target 'src/d8o8.vhd', needed by 'fw/7i80hd16/SVST8_4.BIT'. Stop.
make[1]: Leaving directory '/home/installer/Dev/hostmot2-from-github/hostmot2-firmware'
debian/rules:5: recipe for target 'build' failed
make: *** [build] Error 2
dpkg-buildpackage: error: debian/rules build gave error exit status 2
find . -type f -exec grep -nH -e d8o8.vhd {} +
./scripts/build.py:49: 'd8o8.vhd',
./Makefile:12: PinExists.vhd CountPinsInRange.vhd d8o8.vhd dpll.vhd hostmotid.vhd \
Last edit: 01 Apr 2017 06:05 by jCandlish. Reason: clarity
01 Apr 2017 11:37 #90690
You could extract the current source list from the appropriate project file (or just use the project file as is)
Time to create page: 0.092 seconds
