TB6560-T3 CNC Board
28 Apr 2017 21:30 #92307
by Mike29
TB6560-T3 CNC Board was created by Mike29
In the spirit of trying to help out the next user here is a StepConf configuration for a "Chinese" TB6560 controller. I've been tuning for awhile as no specific timing information was provided with the board. The tuning process was iterative each time I lost steps or the home position during a cut. The StepTimingCalculator on the LinuxCNC wiki was very helpful.
Dell Optiplex 760 using the on-board parallel port and video card.
NEMA 23 motors
1.5Kw water cooled spindle (110V)
Huanyang VFD
NEMA 23 motors
Huanyang VFD
- Thank you received: 5925
30 Apr 2017 22:18 #92385
Replied by tommylight on topic TB6560-T3 CNC Board
2 weeks ago i was called to change a computer for a cnc plasma cutter, it had that same board and was using Mach3. New computer with Linuxcnc, and since i did not want to spend the day figuring out the step timing, i just set it to 15000, it worked perfectly.
Time to create page: 0.449 seconds
