Mesa: Digital Filters
20 May 2017 20:40 - 21 May 2017 09:01 #93406
by sirop
Mesa: Digital Filters was created by sirop
Hello.
Looking through the newest www.mesanet.com/software/parallel/5i25.zip
I seein pktuart.vhd .
Is it time to update Packet UART hostmot2 driver or yet too early?
This patch
seems to be backwards compatible because of github.com/LinuxCNC/hostmot2-firmware/bl...rc/pktuartr.vhd#L412 ,
doesn't it?
I see
signal FilterReg: std_logic_vector(7 downto 0) := std_logic_vector(to_unsigned(integer(defaultfilter),8));
signal FilterCount: std_logic_vector(7 downto 0);
signal RXDataD: std_logic;
signal RXDataFilt: std_logic;
This patch
/* http://freeby.mesanet.com/regmap
The PktUARTrMode register is used for setting and checking the PktUARTr's
operation mode, timing, and status
Bit 31..30 Unused
Bit 29..22 Filter Register
Bit 21 FrameBuffer has data
Bits 20..16 Frames received
Bits 15..8 InterFrame delay in bit times
Bit 7 Receive Logic active, not an error
Bit 6 RXMask
Bit 5 Unused
Bit 4 RCFIFO Error
Bit 3 RXEnable (must be set to receive packets)
Bit 2 RXMask Enable (enables input data masking when transmitting)
Bit 1 Overrun error (no stop bit when expected) (sticky)
Bit 0 False Start bit error (sticky)
if (rx_mode >= 0) {
// read filter settings from rx register before setting new values
r += hm2->llio->read(hm2->llio, inst->rx_mode_addr, &buff, sizeof(u32));
buff = (((u32)rx_mode) & 0xffff) | (buff & (0xFF << 22));
r += hm2->llio->write(hm2->llio, inst->rx_mode_addr, &buff, sizeof(u32));
doesn't it?
Last edit: 21 May 2017 09:01 by sirop. Reason: patch proposal
21 May 2017 16:19 #93439
Replied by PCW on topic Mesa: Digital Filters
Yes, the filter field is a no-op in the previous version so there's no harm always writing the
value. The filter time should be set to 1/2 a UART bit time (filter time is (1/ClockLow) * (FilterRegValue+1)
At lower baud rates its not possible to set the filter to 1/2 a bit time, in those cases, it should be set all the way up (255)
= 25.6 usec at 100 MHz ClockLow, and 76.8 usec at 33 Mhz ClockLow
The following user(s) said Thank You: sirop
21 May 2017 17:05 - 21 May 2017 17:06 #93442
by sirop
(1/ClockLow) * (FilterRegValue+1)= 0.5*bittime => FilterRegValue = 0.5*bittime*ClockLow -1
Should FilterRegValue then be rouned up or down ?
For instance:
76,800 bit/s with bittime=13.0 µs at ClockLow=33Mhz:
0.5*13.0*33-1 = 213.5
Is FilterRegValue then 214 or 213?
Replied by sirop on topic Mesa: Digital Filters
For instance:
Last edit: 21 May 2017 17:06 by sirop.
21 May 2017 17:22 #93443
At 76.8 KBaud it really doesn't matter, where it becomes critical is very high baud rates (say 10 MBaud and 33 MHz clock low) where the filter value is low, in this case rounding down is better as it will result in better tolerance of serial data timing distortions. So as a general rule, rounding down is preferable
28 May 2017 22:38 #93763
by sirop
I once used a standard TTL converter where the quality of the Rx signal deteriorated over time. The scope showed that
square wave lost its steepness and looked more and more like a triangle wave.
So as far as hm2_pktuart_setup function is concerned, is it worth then to let the user pass a FilterReg value somewhat different from 0.5*bittime*ClockLow -1 in such a case?
05 Jun 2017 14:33 #94095
by sirop
Time to create page: 0.276 seconds
