Advice for future rebuilds
- Thank you received: 5321
23 May 2017 14:45 #93549
Replied by PCW on topic Advice for future rebuilds
If you want a step/dir Ethernet solution, I would suggest a 7I76E as its currently
fully supported and needs fewer cables. If you want to add encoder feedback
to the step/dir channels you can add a 7I85 or 7I85S later.
AFAIK PathPilot only runs on RTAI so will not currently support our Ethernet cards.
Pathpilot looks nice and has a great conversational interface, _but_ its really made only
to support Tormach products. You will get better support and easier updates if you stay with stock
LinuxCNC (perhaps with one of the newer GUIs)
- tecno
- Thank you received: 127
23 May 2017 18:07 #93556
by tecno
Replied by tecno on topic Advice for future rebuilds
Is there anybody in Europe that has 2 pcs 7i76E and 1pcs 7i85 in stock?
23 May 2017 18:40 #93560
EUSurplus may have them
- tecno
23 May 2017 19:24 #93563
by tecno
How to connect 7i73 to 7i76E?
- Thank you received: 4144
23 May 2017 19:48 #93564
You just grab an ethernet cable, plug one end into the 7i73, chop the other end off and connect to the serial port pins on the 7i76e.
I have to say the 7i76e has been very nice to work with on my build. Everything just works as it should! Don't forget it has 2 MPG encoders as well as a spindle encoder.
I have never understood the fascination with PathPilot on non Tormach hardware. It seems to cause a lot of issues as people work around the locked in stuff.
Replied by rodw on topic Advice for future rebuilds
- tecno
23 May 2017 20:12 #93566
by tecno
Thank you, good information I have missed re MPG“s.
Cheers
Bengt
Cheers
Bengt
23 May 2017 20:30 #93569
I use one MPG input for a wireless remote and the other reserved for a console which I will probably never add.
Also there are some A/D analog inputs available, With the benefit of hindsight, I would leave them unconnected until I really needed them for Digital IO. Consider adding a separate home switch. I have found seperate home/limits much nicer to configure than shared ( I have one of them). Its not as though you will be short of inputs now!
- tecno
26 May 2017 11:48 - 26 May 2017 11:49 #93655
by tecno
PCW
What part# for cable to connect 7i85S to 7i76E? Can not find anything in your shop. I am ready to order now.
Cheers
Bengt
Cheers
Bengt
Last edit: 26 May 2017 11:49 by tecno.
- Thank you received: 1472
26 May 2017 12:37 #93656
Replied by Todd Zuercher on topic Advice for future rebuilds
This is the part on Mesa's store.
store.mesanet.com/index.php?route=produc...74_81&product_id=273
But it is just a simple flat header to parallel port cable, the same as would be used to connect to a motherboard's parallel port header pins.
- tecno
26 May 2017 12:53 #93657
by tecno
OK, the word parallel seemed to be wrong.
Time to create page: 0.117 seconds
