How to work with my plc?
- zhcong
02 Jun 2017 13:40 #94008
by zhcong
How to work with my plc? was created by zhcong
hi, I have a siemens S7-300 plc. I want use linuxcnc to control this plc and plc control servo motor. servo motor simulation by matlab. It commnuicate use opc protocol.
And it is important that linuxcnc change the storage of the plc, how it works?
- Thank you received: 4636
02 Jun 2017 22:17 #94024
Replied by andypugh on topic How to work with my plc?
I am not sure what part you expect LinuxCNC to play in this system.
What do you want LinuxCNC to send to the PLC? Where does Matlab fit in?
- zhcong
03 Jun 2017 01:12 #94026
by zhcong
Replied by zhcong on topic How to work with my plc?
thanks for reply.
This is a simulation environment, I use matlab simulate the servo motor. I want linuxcnc send control signal to plc, and plc control servo motor. I don't know what send to plc, maybe like X-axis pulse signal. I dont need to achieve all, it's only a cnc lab environment.
03 Jun 2017 19:54 #94038
I would be surprised if Matlab is fast enough-responding and real-time enough to do the job.
(Simulink compiled for realtime hardware will certainly work for this sort of thing)
I think you would end up using LinuxCNC, then Modbus2HAL to link to the PCL, then to Matlab.
But I have this feeling that this is an over-complex and not super-useful configuration.
The following user(s) said Thank You: zhcong
- zhcong
04 Jun 2017 01:49 #94042
by zhcong
Thanks!!
I will try it. This a cnc lab environment, so I don't need real "real-time".
And Thanks again。
And Thanks again。
04 Jun 2017 08:48 #94045
In that case you probably don't need LinuxCNC.
Time to create page: 0.094 seconds
