7i76e No field outputs except in sample config
- blazini36
- Thank you received: 167
24 Aug 2017 02:25 #97953
by blazini36
7i76e No field outputs except in sample config was created by blazini36
I have several configs generated by Pconf for the 7i76e and none of them will drive an output pin high using halshow in axis or halrun in terminal. I know I'm doing something wrong because the 7i76es sample config I found a while back from PCW will drive the pin in halshow.
Trying to execute "setp hm2_7i76e.0.7i76.0.0.output-00 true" only works in the sample config
Maybe somebody can point out what's wrong with my Hal file (or whatever else)
# Generated by PNCconf at Sun Jul 16 19:11:56 2017
# overwritten when you run PNCconf again
loadrt trivkins
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
loadrt hostmot2
loadrt hm2_eth board_ip="10.10.10.10" config="firmware=hm2/7i76/7i76e.BIT num_encoders=1 num_pwmgens=0 num_stepgens=5 sserial_port_0=00xxxx"
setp hm2_7i76e.0.watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.y,pid.z,pid.s
loadrt abs names=abs.spindle
loadrt lowpass names=lowpass.spindle
loadrt scale names=scale.spindle
addf hm2_7i76e.0.read servo-thread
addf pid.x.do-pid-calcs servo-thread
addf pid.y.do-pid-calcs servo-thread
addf pid.z.do-pid-calcs servo-thread
addf pid.s.do-pid-calcs servo-thread
addf scale.spindle servo-thread
addf abs.spindle servo-thread
addf lowpass.spindle servo-thread
addf hm2_7i76e.0.write servo-thread
setp hm2_7i76e.0.dpll.01.timer-us -50
setp hm2_7i76e.0.stepgen.timer-number 1
# external output signals
# --- CAM0_TRIGGER_OUT ---
net cam0_trigger_OUT hm2_7i76e.0.7i76.0.0.output-00
# --- CAM0_FLASH_TRIGGER_OUT ---
net cam0_flash_trigger_OUT hm2_7i76e.0.7i76.0.0.output-01
# --- CAM1_TRIGGER_OUT ---
net cam1_trigger_OUT hm2_7i76e.0.7i76.0.0.output-04
# --- CAM1_FLASH_TRIGGER_OUT ---
net cam1_flash_trigger_OUT hm2_7i76e.0.7i76.0.0.output-05
# --- FLASH_INTENSITY_AOUT ---
# net Flash_intensity_AOUT-enable => hm2_7i76e.0.7i76.0.0..spinena
# net Flash_intensity_AOUT-output => hm2_7i76e.0.7i76.0.0..spinout
# net Flash_intensity_AOUT-direction => hm2_7i76e.0.7i76.0.0..spindir
# external input signals
# --- MIN-X ---
net min-x <= hm2_7i76e.0.7i76.0.0.input-00
# --- MAX-X ---
net max-x <= hm2_7i76e.0.7i76.0.0.input-01
# --- HOME-X ---
net home-x <= hm2_7i76e.0.7i76.0.0.input-02
# --- MIN-Y ---
net min-y <= hm2_7i76e.0.7i76.0.0.input-08
# --- MAX-Y ---
net max-y <= hm2_7i76e.0.7i76.0.0.input-09
# --- HOME-Y ---
net home-y <= hm2_7i76e.0.7i76.0.0.input-10
# --- DIN-01 ---
net Park-Cams <= hm2_7i76e.0.7i76.0.0.input-16
# --- DIN-01 ---
net cue-sense <= hm2_7i76e.0.7i76.0.0.input-17
# AXIS X
setp pid.x.Pgain [AXIS_0]P
setp pid.x.Igain [AXIS_0]I
setp pid.x.Dgain [AXIS_0]D
setp pid.x.bias [AXIS_0]BIAS
setp pid.x.FF0 [AXIS_0]FF0
setp pid.x.FF1 [AXIS_0]FF1
setp pid.x.FF2 [AXIS_0]FF2
setp pid.x.deadband [AXIS_0]DEADBAND
setp pid.x.maxoutput [AXIS_0]MAX_OUTPUT
setp pid.x.error-previous-target true
setp pid.x.maxerror .0005
net x-index-enable <=> pid.x.index-enable
net x-enable => pid.x.enable
net x-pos-cmd => pid.x.command
net x-vel-cmd => pid.x.command-deriv
net x-pos-fb => pid.x.feedback
net x-output => pid.x.output
# Step Gen signals/setup
setp hm2_7i76e.0.stepgen.00.dirsetup [AXIS_0]DIRSETUP
setp hm2_7i76e.0.stepgen.00.dirhold [AXIS_0]DIRHOLD
setp hm2_7i76e.0.stepgen.00.steplen [AXIS_0]STEPLEN
setp hm2_7i76e.0.stepgen.00.stepspace [AXIS_0]STEPSPACE
setp hm2_7i76e.0.stepgen.00.position-scale [AXIS_0]STEP_SCALE
setp hm2_7i76e.0.stepgen.00.step_type 0
setp hm2_7i76e.0.stepgen.00.control-type 1
setp hm2_7i76e.0.stepgen.00.maxaccel [AXIS_0]STEPGEN_MAXACCEL
setp hm2_7i76e.0.stepgen.00.maxvel [AXIS_0]STEPGEN_MAXVEL
# ---closedloop stepper signals---
net x-pos-cmd <= axis.0.motor-pos-cmd
net x-vel-cmd <= axis.0.joint-vel-cmd
net x-output <= hm2_7i76e.0.stepgen.00.velocity-cmd
net x-pos-fb <= hm2_7i76e.0.stepgen.00.position-fb
net x-pos-fb => axis.0.motor-pos-fb
net x-enable <= axis.0.amp-enable-out
net x-enable => hm2_7i76e.0.stepgen.00.enable
# ---setup home / limit switch signals---
net home-x => axis.0.home-sw-in
net min-x => axis.0.neg-lim-sw-in
net max-x => axis.0.pos-lim-sw-in
# AXIS Y
setp pid.y.Pgain [AXIS_1]P
setp pid.y.Igain [AXIS_1]I
setp pid.y.Dgain [AXIS_1]D
setp pid.y.bias [AXIS_1]BIAS
setp pid.y.FF0 [AXIS_1]FF0
setp pid.y.FF1 [AXIS_1]FF1
setp pid.y.FF2 [AXIS_1]FF2
setp pid.y.deadband [AXIS_1]DEADBAND
setp pid.y.maxoutput [AXIS_1]MAX_OUTPUT
setp pid.y.error-previous-target true
setp pid.y.maxerror .0005
net y-index-enable <=> pid.y.index-enable
net y-enable => pid.y.enable
net y-pos-cmd => pid.y.command
net y-vel-cmd => pid.y.command-deriv
net y-pos-fb => pid.y.feedback
net y-output => pid.y.output
setp hm2_7i76e.0.stepgen.01.dirsetup [AXIS_1]DIRSETUP
setp hm2_7i76e.0.stepgen.01.dirhold [AXIS_1]DIRHOLD
setp hm2_7i76e.0.stepgen.01.steplen [AXIS_1]STEPLEN
setp hm2_7i76e.0.stepgen.01.stepspace [AXIS_1]STEPSPACE
setp hm2_7i76e.0.stepgen.01.position-scale [AXIS_1]STEP_SCALE
setp hm2_7i76e.0.stepgen.01.step_type 0
setp hm2_7i76e.0.stepgen.01.control-type 1
setp hm2_7i76e.0.stepgen.01.maxaccel [AXIS_1]STEPGEN_MAXACCEL
setp hm2_7i76e.0.stepgen.01.maxvel [AXIS_1]STEPGEN_MAXVEL
net y-pos-cmd <= axis.1.motor-pos-cmd
net y-vel-cmd <= axis.1.joint-vel-cmd
net y-output <= hm2_7i76e.0.stepgen.01.velocity-cmd
net y-pos-fb <= hm2_7i76e.0.stepgen.01.position-fb
net y-pos-fb => axis.1.motor-pos-fb
net y-enable <= axis.1.amp-enable-out
net y-enable => hm2_7i76e.0.stepgen.01.enable
net home-y => axis.1.home-sw-in
net min-y => axis.1.neg-lim-sw-in
net max-y => axis.1.pos-lim-sw-in
# SPINDLE S
setp pid.s.Pgain [SPINDLE_9]P
setp pid.s.Igain [SPINDLE_9]I
setp pid.s.Dgain [SPINDLE_9]D
setp pid.s.bias [SPINDLE_9]BIAS
setp pid.s.FF0 [SPINDLE_9]FF0
setp pid.s.FF1 [SPINDLE_9]FF1
setp pid.s.FF2 [SPINDLE_9]FF2
setp pid.s.deadband [SPINDLE_9]DEADBAND
setp pid.s.maxoutput [SPINDLE_9]MAX_OUTPUT
setp pid.s.error-previous-target true
net spindle-index-enable <=> pid.s.index-enable
net spindle-enable => pid.s.enable
net spindle-vel-cmd-rpm => pid.s.command
net spindle-vel-fb-rpm => pid.s.feedback
net spindle-output <= pid.s.output
setp hm2_7i76e.0.encoder.00.counter-mode 0
setp hm2_7i76e.0.encoder.00.filter 1
setp hm2_7i76e.0.encoder.00.index-invert 0
setp hm2_7i76e.0.encoder.00.index-mask 0
setp hm2_7i76e.0.encoder.00.index-mask-invert 0
setp hm2_7i76e.0.encoder.00.scale [SPINDLE_9]ENCODER_SCALE
net spindle-revs <= hm2_7i76e.0.encoder.00.position
net spindle-vel-fb-rps <= hm2_7i76e.0.encoder.00.velocity
net spindle-index-enable <=> hm2_7i76e.0.encoder.00.index-enable
net spindle-vel-cmd-rps <= motion.spindle-speed-out-rps
net spindle-vel-cmd-rps-abs <= motion.spindle-speed-out-rps-abs
net spindle-vel-cmd-rpm <= motion.spindle-speed-out
net spindle-vel-cmd-rpm-abs <= motion.spindle-speed-out-abs
net spindle-enable <= motion.spindle-on
net spindle-cw <= motion.spindle-forward
net spindle-ccw <= motion.spindle-reverse
net spindle-brake <= motion.spindle-brake
net spindle-revs => motion.spindle-revs
net spindle-at-speed => motion.spindle-at-speed
net spindle-vel-fb-rps => motion.spindle-speed-in
net spindle-index-enable <=> motion.spindle-index-enable
sets spindle-at-speed true
# Use ACTUAL spindle velocity from spindle encoder
# spindle-velocity bounces around so we filter it with lowpass
# spindle-velocity is signed so we use absolute component to remove sign
# ACTUAL velocity is in RPS not RPM so we scale it.
setp scale.spindle.gain 60
setp lowpass.spindle.gain 1.000000
net spindle-vel-fb-rps => scale.spindle.in
net spindle-fb-rpm scale.spindle.out => abs.spindle.in
net spindle-fb-rpm-abs abs.spindle.out => lowpass.spindle.in
net spindle-fb-rpm-abs-filtered lowpass.spindle.out
# connect miscellaneous signals
# ---HALUI signals---
net joint-select-a halui.joint.0.select
net x-is-homed halui.joint.0.is-homed
net jog-x-pos halui.jog.0.plus
net jog-x-neg halui.jog.0.minus
net jog-x-analog halui.jog.0.analog
net jog-selected-pos halui.jog.selected.plus
net jog-selected-neg halui.jog.selected.minus
net spindle-manual-cw halui.spindle.forward
net spindle-manual-ccw halui.spindle.reverse
net spindle-manual-stop halui.spindle.stop
net machine-is-on halui.machine.is-on
net jog-speed halui.jog-speed
# ---coolant signals---
net coolant-mist <= iocontrol.0.coolant-mist
net coolant-flood <= iocontrol.0.coolant-flood
# ---probe signal---
net probe-in => motion.probe-input
# ---motion control signals---
net in-position <= motion.in-position
net machine-is-enabled <= motion.motion-enabled
# ---digital in / out signals---
# ---estop signals---
net estop-out => iocontrol.0.emc-enable-in
# ---toolchange signals for custom tool changer---
net tool-number <= iocontrol.0.tool-prep-number
net tool-change-request <= iocontrol.0.tool-change
net tool-change-confirmed => iocontrol.0.tool-changed
net tool-prepare-request <= iocontrol.0.tool-prepare
net tool-prepare-confirmed => iocontrol.0.tool-preparedPlease Log in or Create an account to join the conversation.
- Thank you received: 5291
24 Aug 2017 02:35 - 24 Aug 2017 02:35 #97954
Replied by PCW on topic 7i76e No field outputs except in sample config
You would not be able to control hm2_7i76e.0.7i76.0.0.output-00 with halcmd or halshow because the pin is
already linked to a signal in your hal file:
Last edit: 24 Aug 2017 02:35 by PCW.
- blazini36
24 Aug 2017 03:59 #97955
by blazini36
Replied by blazini36 on topic 7i76e No field outputs except in sample config
You're right about the config, I commented it out and it ran, but halcmd I ran without pointing to a hal file, just:
halrun
loadrt hostmot2
loadrt hm2_eth board_ip="10.10.10.10" config="num_stepgens=5 sserial_port_0=00xxx"
Not sure what I'm missing on that. All the little nuances of hal are a bit overwhelming but I appreciate the help.
halrun
loadrt hostmot2
24 Aug 2017 13:25 #97963
In halrun, you would need to start a thread and addf the hm2_xxxx read and write functions to that thread to have any I/O work.
Loading the driver just probes the hardware and sets up the pins but does not do the required periodic reads and writes.
- Thank you received: 4646
30 Aug 2017 12:57 #98204
Replied by andypugh on topic 7i76e No field outputs except in sample config
halrun
loadrt hostmot2
loadrt threads
addf hm2_7i76e.0.read thread1
addf hm2_7i76e.0.write thread1
start
(the "start" is important)
loadrt hostmot2
loadrt threads
start
Time to create page: 0.117 seconds
