7i92 7i77 7i84 Configuration
19 Sep 2017 19:32 #99128
by lawley
7i92 7i77 7i84 Configuration was created by lawley
Hi there
I am new to LinuxCNC, I am busy converting a Weiler lathe, I have a 7i92 with a 7i77 and 7i84 Mesa card. I have converted the HAL and INI files from a 5i25 configuration. If I go into the HAL meter, I can see all the pins on the 7i77 and the inputs and outputs work as expected, however although I can see all of the 7i84 pins, all of the inputs show as TRUE, even though nothing is connected to them.
The fact that the 7i84 pins show, means that the card has been seen by the 7i92.
Any suggestions would be appreciated.
19 Sep 2017 19:46 - 19 Sep 2017 19:46 #99132
Replied by PCW on topic 7i92 7i77 7i84 Configuration
That's really weird, have you checked you field power ( both A and B )?
Sounds like something wrong there
Last edit: 19 Sep 2017 19:46 by PCW.
The following user(s) said Thank You: lawley
21 Sep 2017 16:04 #99214
by lawley
Replied by lawley on topic 7i92 7i77 7i84 Configuration
Thank you for your reply.
I had the W1 jumper selected to have VIN connected to VFieldB but had mistakenly connected the power to VFieldB instead of VIN. everything is now working.
