7i76E with 7i77 or better 7i92 with 7i76 and 7i77
I am rebuilding with a friend an Deckel FP3 with automatic tool changer.
The machine has 4 servo amps with analog in. The encoders are connected directly to the servo amps, and the glas scales should go to mesa cards for position feed back.
Because of the tool change, I will need about 50 Input and 20 outputs (including home and ref switches, etc.)
So I looked for different MESA hardware combinations and ended up with two solutions:
1 7i76E
1 7i77
€ 449,44
(one DB-25 and two SSerial ports left for extension)
or
1 7i92
1 7i77
1 7i76
€ 456,34
(two SSerial Ports left for extension)
from price side, there is only a minimal difference, so that is no question.
I have seen, that there is a bit file for the 7i76E (Justio), what does this mean. I would like to remain all hal pin, except the step/dir part. Is there a possibility to use that pin also as IO, even if they only do support 5 V it would be a possibility to connect some hardware buttons to that part.
Any other solutions are also welcome!, May be anyone has already a Deckel FP3 ATC running with MESA hardware.
Norbert
have you ever tried the 7i76e_JUSTIO bitfile? I am not sure if I can use that one to make the not needed Step/Dir pins availible.
Norbert
The other thing I've seen guys do is use the 7i92/7i74/7i77 and then run up to 4 I/O smart serial daughter cards off the 7i74. Say a 7i70 & 7i71 which give either 48 inputs or 48 outputs each.That may be a more mainstream approach but check the voltage specs suit your hardware. I think both are good at 24 volts.
This does not need a different bit file and is true of all bitfiles (if special output functions like stepgens, PWMgens, UARTs
etc are disabled in hal, their pins revert to being GPIO )
For example, if you have num_stepgens=3 on a 7I76E, step4/dir4, step5/dir5 are available as general purpose outputs
They cannot be used as inputs because the step/dir output drivers on the card are output only
A single 7i77 connected to a 5i25 plus provides a lot of inputs and outputs and you can still connect a popular 7i84 that we often use to the panel interface on the 7i77 and still have the expansion port of the 5i25 available.
On eusurplus store, 5i25+7i77+7i84 +- 430€ and you will have 64 inputs and 32 outputs
PCW, could you name the pin of step and dir 4 and 5, so I can try here on my desktop test environment.
Thanks Norbert
If the servo amplifiers are analog, why do you need to generate steps? Is a requirement to have Ethernet?
I do not want to use any more internal cards, that is the only reason to select the 7i76E.
I have one Laptop, and I can plug it to any of my machines, so I save hardware
A friend of mine is designing a very universal control panel, that will also work with Ethernet connections to control any kind of machine with MESA Hardware. As soon as it is available, I will post it here, as he wants to offer that one also for sale.
And be sure, I will order at EU-Surplus, as in the past, I have been very happy with your service!
Norbert
For example with the default 192.168.1.121 address:
mesaflash --device 7i76e --readhmid
or with the EEPROM 10.10.10.10 address:
mesaflash --device 7i76e --addr 10.10.10.10 --readhmid
- Thank you received: 5942
5i25 OR 6i25 OR 7i92 >>>to 7i77 AND 7i74>>>>to 7i70 AND 7i71>>>>another 7i84 OR 7i70 OR 7i71 when needed. So far i have 2 x 7i84 left !!! That is i never needed or came close to using all the IO pins on the 7i77 and 7i70 and 7i71 ! That makes 64 outputs and 80 inputs.
That also makes wiring less messy and eventual troubleshooting much easier.
As a rule i connect only drive enable and limit switches to the 7i77, everything else on the separate input and output cards.
This is the second retrofit using the same setup, except instead of 5i25 this one uses 7i92. Makes a huge difference having a single UTP cable instead of nearly 15 kilos of wires that were there. I used mesa cards on other retrofits but on plasma cutters i use only a single 5i25/7i77 combo. Have a 7i76E that is going to be installed on a router soon, a friend made a nice job of building the metal parts for it.
forum.linuxcnc.org/30-cnc-machines/33529-hurco-bmc-20p-retrofit
