Raspberry Pi 4 with Mesa 7c81
05 Jul 2022 19:30 - 05 Jul 2022 19:31 #246678
Replied by PCW on topic Raspberry Pi 4 with Mesa 7c81
It would require a special bitfile and a special cable
a simpler (though more expensive) would be to add a 7I85/7I85S
and a 7I83, or a 7I77.
I wish we made a simple 25 pin analog/encoder interface
Last edit: 05 Jul 2022 19:31 by PCW.
07 Jul 2022 20:24 #246830
by boyzo
Replied by boyzo on topic Raspberry Pi 4 with Mesa 7c81
I decided to go with 7c81 + 7i77.
Then I will do what is suggested in this post:
" the easiest way to generate a working hal/ini configuration for the 7C81 is to use pncconf and setup say a 5I25+G540 configuration. Then change the card name in the .ini file and driver name in the hal file".
One more think. What cable/connector I need to buy to connect 7c81 to 7i77.
07 Jul 2022 21:45 #246840
If 18" is long enough, Mesa's DB25M-IDC26 CABLE should be correct
- haziqiqbal9421@gmail.com
29 Aug 2022 15:17 - 29 Aug 2022 15:34 #250689
by haziqiqbal9421@gmail.com
Replied by haziqiqbal9421@gmail.com on topic Raspberry Pi 4 with Mesa 7c81
hey! i was following along and this thread was really helpful. I have a similar setup with RPi and Mesa 7c81 but I have 5-axis breakout board (HW356). This is how it looks like
I have selected "One Partport" in PNCconf but the parallel port options are very different from Stepconf. Could you please post a screenshot of parallel port configuration in pncconf for my breakout board. Thanks!
Last edit: 29 Aug 2022 15:34 by haziqiqbal9421@gmail.com.
29 Aug 2022 19:11 #250724
You should select a parallel port like interface in pncconf, not a parallel port
(I would suggest the G540 option)
02 Sep 2022 11:33 #250993
I have the following settings:
Base Information
Axis configuration: XYZ with Include Spindle
Mesa0 PCI/ Etho/ Partport with "One Partport"
Mesa 0
Board Name: 5i25-Internal Data
Firmware: G540x2
Num of encoder: 0
Nim of PWM: 0
Num of step generators: 3
And I have used I/O connector 3 which you said will be P1 on Mesa7c81.
Sorry I couldn't understand what you meant by "parallel port like". I would really appreciate your help.
Base Information
Mesa 0
Firmware: G540x2
Num of encoder: 0
Nim of PWM: 0
02 Sep 2022 14:09 #251005
The G540 _is_ a parallel port like configuration
(as opposed to a more complex configuration for a breakout like a 7I76 or 7I77)
05 Sep 2022 15:32 - 05 Sep 2022 15:33 #251235
I guess I am still too dumb to understand. I have used G540 in firmware and edited in the hm2_pci to hm2_rpspi and hm2_5i25.0 to hm2_7c81.0 inĀ .hal and .ini file. What should I do with the partport? Should I use "One Partport" or "None" in pncconf?
Last edit: 05 Sep 2022 15:33 by haziqiqbal9421@gmail.com.
05 Sep 2022 16:18 #251236
There is no parport so select "none"
15 Sep 2022 19:58 #252039
Thanks for the help but there is still no movement. Here is what I have done so far.
Installed mesaflash from github.com/LinuxCNC/mesaflash
Downloaded 7c81_g540x2d.bit file from www.mesanet.com/software/parallel/7c81.zip
sudo mesaflash --device 7c81 --addr /dev/spidev0.0 --spi readhmid
sudo mesaflash --device 7c81 --addr /dev/spidev0.0 --write 7c81_g540x2d.bit
sudo mesaflash --device 7c81 --addr /dev/spidev0.0 --spi reload
Everything went fine but when I did the HALRUN, it gave errors that I couldn't understand. hm2_rpspi is probably not working and show pin is not showing anything
halrun
halcmd: loadrt hostmot2
Note: Using POSIX non-realtime
hm2: loading Mesa Hostmot2 driver version 0.15
halcmd: loadrt hm2_rpspi
rmmod: ERROR: ../libkmod/libkmod-module.c: 793 kmod_module_remove_module() could not remove 'spi_bcm2835': Operation not permitted
rmmod: ERROR: could not remove module 'spi_bcm2835': Operation not permitted
hm2_rpspi: ERROR: Failed to execute '/bin/rmmod spi_bcm2835'
hm2_rpspi: can't open /dev/mem
hm2_rpspi: cannot map peripheral memory
hm2_rpspi: rtapi_app_main: Permission denied (-13)
<stdin>:2: waitpid failed /home/pi/linuxcnc-dev/bin/rtapi_app hm2_rpspi
<stdin>:2: /home/pi/linuxcnc-dev/bin/rtapi_app exited without becoming ready
<stdin>:2: insmod for hm2_rpspi failed, returned -1
halcmd: show pin
Component Pins:
Owner Type Dir Value Name
I've connected the 5-axis breakout board with P1 of Mesa 7c81 and my jumper positions are also default on the mesa board. Also when I launch my configuration, there is a pop-up at the bottom right corner which says:
hm2/hm2_7c81.0: Watchdog has bit! (set the .has-bit pin to False to resume)
Kindly help in these regards
halrun
halcmd: show pin
Component Pins:
Time to create page: 0.151 seconds
