Raspberry Pi 4 with Mesa 7c81
12 Jan 2021 18:19 - 12 Jan 2021 18:20 #195102
Replied by PCW on topic Raspberry Pi 4 with Mesa 7c81
Read the current configuration:
sudo mesaflash --device 7c81 --addr /dev/spidev0.0 --spi --readhmid
(I would verify that this works reliably before trying to flash new firmware)
Write new firmware to the flash EEPROM:
sudo mesaflash --device 7c81 --addr /dev/spidev0.0 --spi --write 7c81_g540x2d.bit
Load the FPGA from the current flash EEPROM image:
sudo mesaflash --device 7c81 --addr /dev/spidev0.0 --spi --reload
Last edit: 12 Jan 2021 18:20 by PCW.
12 Jan 2021 18:52 #195105
by JohnG
Replied by JohnG on topic Raspberry Pi 4 with Mesa 7c81
Thank you so much for the help!
12 Jan 2021 19:19 #195107
BTW the easiest way to generate a working hal/ini configuration for the 7C81 is to use
pncconf and setup say a 5I25+G540 configuration. Then change the card name in the .ini file
and driver name in the hal file
13 Jan 2021 05:29 #195175
by JohnG
Can’t thank you guys enough for all of your time and help. I have successfully installed Mesaflash but now when I try read from the 7c81 with these two options here are my results:
Results in “unrecognized option ‘—addr/dev/spidev0.0’”
sudo mesaflash --device 7c81 --spi --readhmid
Results in
“open: Bad address
No 7c81 board found”
Results in
“open: Bad address
13 Jan 2021 05:45 #195176
missing space?
13 Jan 2021 05:48 #195177
by JohnG
Where? I have looked back over this and tried several times
13 Jan 2021 05:56 #195179
by JohnG
I don’t think that’s it. Is there anything else you can think would result in it not seeing the 7c81. I thought I had it!
13 Jan 2021 06:00 - 13 Jan 2021 06:02 #195180
Works for me, the error shows that the --addr token is merged with the spi device name so
sudo mesaflash --device 7c81 --addr/dev/spidev0.0 --spi --readhmid
mesaflash: unrecognized option '--addr/dev/spidev0.0'
but
open: No such file or directory
No 7C81 board found
Which is the correct result since this PC has no /dev/spidev0.0
but
No 7C81 board found
Last edit: 13 Jan 2021 06:02 by PCW.
13 Jan 2021 06:24 #195182
by JohnG
I missed the space after addr. My message is now the same as yours except I have a 7c81 connected...
The connection is working as I am able to manually toggle pins using halcmd. (Turning user leds on and off)
I don’t know what to think. Can’t understand why it won’t read the board but nervous as my ultimate goal is to flash it with the g540_x2d configuration
13 Jan 2021 06:28 - 13 Jan 2021 06:30 #195183
Do you have the latest Mesaflash and LinuxCNC?
There was a problem with earlier versions where running the hm2_rpspi
driver disabled mesaflash until a reboot.
Also how long is your connecting cable (it should be no longer than ~2 inches)
Last edit: 13 Jan 2021 06:30 by PCW.
Time to create page: 0.106 seconds
