7i96 ethernet problem
23 Nov 2020 17:42 #190127
by ioiotutu
7i96 ethernet problem was created by ioiotutu
i have a new card mesa 7i96. Card is connected at ip 192.168.1.121 and i have response at ping command.
At the command: "mesaflash --device 7i96 --addr 192.168.1.121 --readhmid" the answer is:
"unsupported ethernet device ????????????? at 192.168.1.121"
"NO 7I96 board found"
If I make the same thing with my old 7i96 i have right response from the card.
somebody has the same problem?
any suggestions?
Thanks.
any suggestions?
Thanks.
- Thank you received: 5933
23 Nov 2020 18:02 #190129
Replied by tommylight on topic 7i96 ethernet problem
ip a
23 Nov 2020 18:07 #190130
by ioiotutu
Replied by ioiotutu on topic 7i96 ethernet problem
ip a response is the list of my pc network interfaces.
The pc address is right (192.168.1.3) and ping command (ping 192.168.1.121) is OK.
23 Nov 2020 18:32 - 24 Nov 2020 00:25 #190133
Replied by PCW on topic 7i96 ethernet problem
Sounds like failed EEPROM or a test escape of some kind.
You could try re-writing the name with setname:
protocol='direct'
interface='elbp16'
ipaddr='192.168.1.121'
setname 7I96
protocol='direct'
interface='elbp16'
setname 7I96
Last edit: 24 Nov 2020 00:25 by PCW. Reason: fix env for bash
24 Nov 2020 06:16 #190190
by ioiotutu
ok. I try.
Thanks.
Thanks.
25 Nov 2020 15:35 #190262
by ioiotutu
I tried the command under windows. This is the result:
setname 7I96
Old Name: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
New Name: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
Strange chars on response.
I write the response to other command:
mesaflash --device 7I96 --ip 192.168.1.121 --write 7i96d_1pwm.bit
Error: Device name 7I96 is invalid
readhmid
Configuration Name: HOSTMOT2
BoardName : MESA7I96
FPGA Size: 9 KGates
FPGA Pins: 144
Number of IO Ports: 3
Width of one I/O port: 17
Clock Low frequency: 100.0000 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Modules in configuration:
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
ClockFrequency: 100.000 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: IOPort
There are 3 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: StepGen
There are 5 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
Module: QCount
There are 1 of QCount in configuration
Version: 2
Registers: 5
BaseAddress: 3000
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5B00
Instance Stride: 64 bytes
Module: Unknown
There are 1 of Unknown in configuration
Version: 0
Registers: 2
BaseAddress: 7D00
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for
Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir
1 0 IOPort None
14 1 IOPort None
2 2 IOPort None
15 3 IOPort None
3 4 IOPort None
16 5 IOPort None
4 6 IOPort None
17 7 IOPort None
5 8 IOPort None
6 9 IOPort None
7 10 IOPort None
8 11 IOPort Unknown 0 Unknown (Out)
9 12 IOPort Unknown 0 Unknown (Out)
10 13 IOPort Unknown 0 Unknown (Out)
11 14 IOPort Unknown 0 Unknown (Out)
12 15 IOPort Unknown 0 Unknown (Out)
13 16 IOPort Unknown 0 Unknown (Out)
IO Connections for
1 17 IOPort StepGen 0 Step (Out)
14 18 IOPort StepGen 0 Dir (Out)
2 19 IOPort StepGen 1 Step (Out)
15 20 IOPort StepGen 1 Dir (Out)
3 21 IOPort StepGen 2 Step (Out)
16 22 IOPort StepGen 2 Dir (Out)
4 23 IOPort StepGen 3 Step (Out)
17 24 IOPort StepGen 3 Dir (Out)
5 25 IOPort StepGen 4 Step (Out)
6 26 IOPort StepGen 4 Dir (Out)
7 27 IOPort QCount 0 Quad-A (In)
8 28 IOPort QCount 0 Quad-B (In)
9 29 IOPort QCount 0 Quad-IDX (In)
10 30 IOPort SSerial 0 RXData1 (In)
11 31 IOPort SSerial 0 TXData1 (Out)
12 32 IOPort SSerial 0 TXEn1 (Out)
13 33 IOPort Unknown 0 Unknown (Out)
IO Connections for
1 34 IOPort None
14 35 IOPort None
2 36 IOPort None
15 37 IOPort None
3 38 IOPort None
16 39 IOPort None
4 40 IOPort None
17 41 IOPort None
5 42 IOPort None
6 43 IOPort None
7 44 IOPort None
8 45 IOPort None
9 46 IOPort None
10 47 IOPort None
11 48 IOPort None
12 49 IOPort None
13 50 IOPort None
All seems ok but i cannot load bitfile becouse the card name seems wrong or corrupted.
setname 7I96
readhmid
FPGA Size: 9 KGates
FPGA Pins: 144
IDROM Type: 3
Module: WatchDog
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
Version: 0
Registers: 5
BaseAddress: 1000
Module: StepGen
Version: 2
Registers: 10
BaseAddress: 2000
Module: QCount
Version: 2
Registers: 5
BaseAddress: 3000
Module: SSerial
Version: 0
Registers: 6
BaseAddress: 5B00
Module: Unknown
Version: 0
Registers: 2
BaseAddress: 7D00
Module: LED
Version: 0
Registers: 1
BaseAddress: 0200
IO Connections for
1 0 IOPort None
14 1 IOPort None
2 2 IOPort None
15 3 IOPort None
3 4 IOPort None
16 5 IOPort None
4 6 IOPort None
17 7 IOPort None
5 8 IOPort None
6 9 IOPort None
7 10 IOPort None
IO Connections for
IO Connections for
1 34 IOPort None
14 35 IOPort None
2 36 IOPort None
15 37 IOPort None
3 38 IOPort None
16 39 IOPort None
4 40 IOPort None
17 41 IOPort None
5 42 IOPort None
6 43 IOPort None
7 44 IOPort None
8 45 IOPort None
9 46 IOPort None
10 47 IOPort None
11 48 IOPort None
12 49 IOPort None
13 50 IOPort None
25 Nov 2020 15:56 #190263
Sounds like the EEPROM is bad/failed
I would send a email to Mesa and ask for a RMA# to repair/replace the card
26 Jan 2022 17:08 #233196
by Talla
Replied by Talla on topic 7i96 ethernet problem
How can i use setname ?
If i try i get an error.
command not found
or
no rigths
Greeting Peter
command not found
or
no rigths
Greeting Peter
26 Jan 2022 18:19 #233206
I get this: (on Mint 20)
peter@peter-HP-EliteDesk-800-G1-USDT:~/pascal/HM2UTILS$ cat setenv
export INTERFACE='elbp16'
export IPADDR='10.10.10.10'
export PROTOCOL='direct'
peter@peter-HP-EliteDesk-800-G1-USDT:~/pascal/HM2UTILS$ ./setenv
peter@peter-HP-EliteDesk-800-G1-USDT:~/pascal/HM2UTILS$ file setname
setname: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), dynamically linked, interpreter /lib64/ld-linux-x86-64.so.2, for GNU/Linux 2.4.0, with debug_info, not stripped
peter@peter-HP-EliteDesk-800-G1-USDT:~/pascal/HM2UTILS$ ./setname foobar
Old Name: 7I96
New Name: foobar
peter@peter-HP-EliteDesk-800-G1-USDT:~/pascal/HM2UTILS$ ./setname 7I96
Old Name: foobar
New Name: 7I96
peter@peter-HP-EliteDesk-800-G1-USDT:~/pascal/HM2UTILS$ md5sum setname
a94833ec586de99e4ef9dc04b8c2d0dd setname
Old Name: 7I96
New Name: foobar
Old Name: foobar
New Name: 7I96
26 Jan 2022 19:15 - 26 Jan 2022 20:18 #233211
by Talla
Can I download HM2UTILS somewhere?
cnc@cnc:~/Dokumente/setname$ file setname
setname: ELF 32-bit LSB executable, Intel 80386, version 1 (SYSV), dynamically linked, interpreter /lib/ld-linux.so.2, not stripped
maybe i have a wrong version
Last edit: 26 Jan 2022 20:18 by Talla.
Time to create page: 0.704 seconds
