[SOLVED] 7i90 25Mhz oscillator on Dev-Board
11 Mar 2021 09:56 - 11 Mar 2021 22:13 #201787
by pauluzs
[SOLVED] 7i90 25Mhz oscillator on Dev-Board was created by pauluzs
Currently i'm trying to adapt the 7i90 firmware on a xc6slx16 FT(G)256 Dev-Board
So i already changed:
The thing that is not quite clear to me is : Where and which clock settings to changed, since the board has a 25Mhz oscillator instead the 50Mhz on the original board. Which clocks and/or setting should be changed, and what are they used for?
I found the following:
i90_x9card.vhd > IDROMConst.vhd
7i90spi.ucf
TopGCSPIHostMot2.vhd
Should only the clk periods be changed from 20 to 40, or should the clk dividers also be adapted?
Thanks in advance,
- The matching pinout in the .ucf file
- The package type in the.xise file
- The pincount and fpga size in the i90_x9card file
- constant ClockHigh90: integer := 200000000;
- constant ClockMed90: integer := 100000000;
- constant ClockLow90: integer := 100000000
7i90spi.ucf
- TIMESPEC "TS_CLK" = PERIOD "CLK" 19.9 ns HIGH 50 %;
- TIMESPEC "TS_COM_SPICLK" = PERIOD "COM_SPICLK" 9 ns HIGH 50 %;
- signal fclk : std_logic;
signal clkfx0: std_logic;
signal clk0_0: std_logic;
signal clklow : std_logic;
signal clkfx1: std_logic;
signal clk0_1: std_logic; - clklow => clklow, -- I/O clock
clkmed => clklow, -- Processor clock
clkhigh => fclk, -- PWM clock - ClockMultH : DCM
generic map (
CLKDV_DIVIDE => 2.0,
CLKFX_DIVIDE => 2,
CLKFX_MULTIPLY => 8, -- 8 FOR 200 MHz
CLKIN_DIVIDE_BY_2 => FALSE,
CLKIN_PERIOD => 20.0, - ClockMultM : DCM
generic map (
CLKFX_DIVIDE => 2,
CLKFX_MULTIPLY => 4, -- 4 FOR 100 MHz
CLKIN_PERIOD => 20.0, - asimplspi: entity work.simplespi8 -- configuration serial EEPROM access SPI port
generic map
buswidth => 8,
div => 7, -- for divide by 8 -- 12.5 MHz
Thanks in advance,
Last edit: 11 Mar 2021 22:13 by pauluzs.
11 Mar 2021 15:45 - 11 Mar 2021 15:52 #201825
Replied by PCW on topic 7i90 25Mhz oscillator on Dev-Board
You would change
ClockMultH CLKFX_MULTIPLY to 16
ClockMultM CLKFX_MULTIPLY to 8
TIMESPEC "TS_CLK" = PERIOD "CLK" 39.8 ns HIGH 50 %;
and both clock periods to 40
Last edit: 11 Mar 2021 15:52 by PCW.
The following user(s) said Thank You: pauluzs
11 Mar 2021 22:09 #201885
by pauluzs
Replied by pauluzs on topic 7i90 25Mhz oscillator on Dev-Board
Thanks ,
With those setting i can confirm the RV901T Led Receiving board as working having 72 5v outputs.
26 Mar 2024 19:55 - 26 Mar 2024 19:56 #296831
by ago_tm
Replied by ago_tm on topic 7i90 25Mhz oscillator on Dev-Board
Hello pauluzs,
Could you kindly share the final changes you did for the hostmot2 xilinx sources or take a look at my github.com/golyakoff/hostmot2-rv901t-7i90/commits/master ? I tried to follow your instruction but get stucked...
It builds but SPI I see garbage on the SPI MISO: here are the details... forum.linuxcnc.org/38-general-linuxcnc-q...king?start=10#296830.
Thank you in advance!
Thanks ,
Last edit: 26 Mar 2024 19:56 by ago_tm.
Time to create page: 0.149 seconds
