Heidenhain LS 904 which EXE?
15 Oct 2021 15:31 - 15 Oct 2021 15:32 #223208
by Wischi
Heidenhain LS 904 which EXE? was created by Wischi
Hello guys,
I bought a Deckel FP2A milling machine that I am planing to convert to LinuxCNC. Currently I am disassembling the machine to clean and inspect it.
The Deckel uses LS 904 glass scales. I seen other people use Heidenhain EXE modules to get a TTL signal for Linux, but my problem is that the LS 904 is not listed in the documentation that Heidenhain provides. Does anyone else have the same scales and found a compatible EXE module?
The scale has a 20um grid and 11uAss signal.
Thanks in advance.
Thanks in advance.
Last edit: 15 Oct 2021 15:32 by Wischi.
15 Oct 2021 19:38 #223219
Replied by PCW on topic Heidenhain LS 904 which EXE?
My guess would be that any EXE box that accepts 11uA signals would work.
15 Oct 2021 20:45 #223229
by Bari
Replied by Bari on topic Heidenhain LS 904 which EXE?
www.heidenhain.com/fileadmin/pdf/en/01_P...E100_ID624602_en.pdf
Also www.dynomotion.com/forum/viewtopic.php?t=1045
I have a bunch of these scales myself. I'm planning on building my own converters from sin/cos to incremental.
www.ichaus.de/PI
www.ichaus.de/PI
15 Oct 2021 23:54 #223259
Replied by cmorley on topic Heidenhain LS 904 which EXE?
In general:
EXE is for 11ua
IBV is for 1vpp
EXE is for 11ua
IBV is for 1vpp
16 Oct 2021 00:14 #223263
by Bari
The cost of new Heidenhain Interpolation and Digitizing Electronics modules are higher than the price of new glass scales and readers from other sources.
www.dropros.com/Digital_Readout_DRO_Specials.htm
16 Oct 2021 10:17 #223289
by Wischi
Replied by Wischi on topic Heidenhain LS 904 which EXE?
Thanks for your answers. The EXE 100 would be a good match, but I can't find any on eBay (Germany). I looked more into the 600 Series and they seem to fit as well. I am going to get three of those. Getting new glass scales is actually more expensive, since the 600 series are often on eBay (again in Germany) for a fair price.
10 Nov 2021 21:05 #226036
by akb1212
Replied by akb1212 on topic Heidenhain LS 904 which EXE?
I woukd also guess that the 600 series EXE cards will work. I don't remember what exact numbers are best, but be aware that there are different ones with different interpolation ratios. I think it's the 612 or something like that which have higher interpolation. I got the one with high interpolation ratio and now have .2 micron resolution with normal 20 um scales. I thik the interpolation rate was 50 on the ones I have. And the price on the good ones are not that much higher than the more common ones. So it's definately worth getting them!
And remember that your encoders will plugg dirrectly in to these cards, but you'd have to make your own solution if you make something yourself with IC-haus chips. And those connectors are not cheap! So very convenient and fast to get used EXE cards.
11 Nov 2021 00:26 #226048
by Bari
I'd need over 50 of them. Plus if found the wiring diagram somewhere.
Time to create page: 0.165 seconds
