7I96 Board not found
02 Nov 2021 14:06 - 02 Nov 2021 14:07 #224988
by Redneck92
7I96 Board not found was created by Redneck92
Hey guys,
I just wanted to flash a new bitfile to my 7i96 and 7i85s combo and if I want to execute
the mesaflash command it says : No 7i96 board found
So, the board IP is 10.10.10.10
My networkcard is set to 10.10.10.11
I can ping the card, I can use my machine aswell. Everything works great expect mesaflash will not find my 7i96.
BUT!!!
When I open Jt´s 7i96 tool and select the 10.10.10.10 adress,
I can read the bitfile, reload the card and so on.
I´m a bit lost right now.
Do I need to uninstall and reinstall mesaflash or what is going on?
When yes, how do I do this? I´m pretty much a linux noob.
Thanks in advance guys.
Mike
BUT!!!
Mike
Last edit: 02 Nov 2021 14:07 by Redneck92.
02 Nov 2021 14:15 - 02 Nov 2021 14:15 #224989
by bevins
Replied by bevins on topic 7I96 Board not found
try this: mesaflash --device 7i96 --addr 10.10.10.10 --readhmid
Last edit: 02 Nov 2021 14:15 by bevins.
The following user(s) said Thank You: Redneck92
02 Nov 2021 15:53 #225000
by Redneck92
Replied by Redneck92 on topic 7I96 Board not found
I feel ashamed that I did not get this myself... I should have tought about putting the ip adress in the command.
It works now. Thank you very much.
I´m sorry that I bothered you with this stuff...
Time to create page: 0.206 seconds
