Mesa for industrial milling machine
03 Nov 2021 07:54 #225075
by A_ekis
Mesa for industrial milling machine was created by A_ekis
Hello everyone, although I have been reading in the shadows for a long time, I have just registered and this is my first post.
I own a mikron cnc milling machine but with dead original electronics.
I have a small machine using mach3 and a cnc lathe but with its own program, in this case I wanted to use linux cnc.
electronics is not my strong point, so I decided to go the easy way to remove everything and put new and modern servo motors.that part is not a problem and it is already solved.
The doubt comes with the card that I need to control everything, from how much I have read in the forum, it seems that the mesa ecosystem is a good solution, but I cannot fully clarify which cards I need for what I want and that is why I have decided open this post.
the requirements would be the control of servos in the three axes, (perhaps a quarter in the future).the main motor through a speed variator (I do not need to control the gearbox of the machine, the variator seems simpler, the use will not be industrial, I do not need to take advantage of all the power of the motor)And also if it is possible to take advantage of the digital scales of the machine to create a double closed loop in the future.
With these requirements, which cards do you recommend buying? and first of all thank you for your help and excuse my English as a translator
03 Nov 2021 21:24 #225154
by RotarySMP
Replied by RotarySMP on topic Mesa for industrial milling machine
If your servo drives take analog control signals, then a 7i97 is a good place to start. Up to 6 axis of closed loop servo control, plus bit of I/O.
I used a 5i25, 7i77 and 7i84 on my Maho, as the 7i97 didn't exist back then. Here is a summary of how I did it.
The following user(s) said Thank You: A_ekis
04 Nov 2021 08:21 - 04 Nov 2021 08:28 #225209
by A_ekis
Replied by A_ekis on topic Mesa for industrial milling machine
Thanks for your help.
His Maho must have come from the same foundry as my mikron, because they are practically the same architecture.
I will look for the information of my servos, although for now I am with a bit small provisionals because I already had them, if everything works well, I will buy some dimensioned according to the machine.
What servo power have you installed to yours? I do not know if he explains it in the video, my English is not too good, and I have only been able to take a look at the video on my mobile due to lack of time.
I have seen that the system for joining the ball screws to the servos is not the same in yours as in mine, yours goes through belts, mine has pinions with a small play between them that will create a backlash, I suppose that the machine would originally correct this with scales and electronics.
I like the system better than yours will have to investigate.
Cheers and thank you again.
Last edit: 04 Nov 2021 08:28 by A_ekis.
07 Nov 2021 10:07 #225554
by RotarySMP
I have the original indramat drives and motors. I think they are nearly 2 hp.
Time to create page: 0.170 seconds
