7i96 connection issues
03 Nov 2021 14:11 #225106
by SSIRon
7i96 connection issues was created by SSIRon
trying to connect to the 7i96 and hitting some road block. i am new to linux so limping along.
first is is i select "edit connections" and nothing happens
second in tommylight's setup i enter in terminal i enter
ssiron@debian:/$ apt-get install network-manager network-manager-gnome
E: Could not open lock file /var/lib/dpkg/lock-frontend - open (13: Permission denied)
E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), are you root?
i believe i am in the root but it does not work
- Thank you received: 5942
03 Nov 2021 18:26 #225129
Replied by tommylight on topic 7i96 connection issues
Add
Sudo
In front of install line.
Sudo
03 Nov 2021 22:11 - 03 Nov 2021 22:12 #225160
by BigJohnT
Replied by BigJohnT on topic 7i96 connection issues
This may help you setup the static IP needed for the 7i96
gnipsel.com/linuxcnc/uspace/debian9-eth.html
My 7i96 Configuration Tool
gnipsel.com/mesa/index.html
JT
JT
Last edit: 03 Nov 2021 22:12 by BigJohnT.
04 Nov 2021 00:12 #225168
by SSIRon
Replied by SSIRon on topic 7i96 connection issues
That was extremely helpful. thank you I think the network manager is not installed. so i got figure that one out as it would be nice to have the interface. regardless apreciate the assist.
04 Nov 2021 00:13 #225169
by SSIRon
thanks tommylight but i believe i have to install networkmanager - i am still working throught it.
04 Nov 2021 00:37 #225172
What install / Linux are you using ?
If you are using the official ISO, download the new 2.8.2 as it should already have NM installed.
Also if you install NM, you should remove WiCd as it will interfere with the NM
04 Nov 2021 00:38 #225173
I also deleted the duplicate topic so it does not cause confusion.
Thank you for your understanding.
The following user(s) said Thank You: SSIRon
04 Nov 2021 20:33 #225260
by SSIRon
I will follow up on this
27 Dec 2021 19:53 #230080
by SSIRon
BigJohnT i am having a difficult time getting throught these steps. I got it loaded on a laptop but running on target machine is proving I am not so briliant.
i can not get past loading wget or Gdebi
this is the type of error i get.
sudo apt-get install gdebi
Reading package lists... Done
Building dependency tree
Reading state information... Done
Package gdebi is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'gdebi' has no installation candidate
27 Dec 2021 20:08 #230084
Sudo apt-get update
Sudo apt install wget gdebi
