7i76e not loading
06 Nov 2021 02:48 #225460
7i76e not loading was created by rodw
This is just starting to happen. Any Ideas?
What path is it looking for?
Master branch on Debian bullseye
but its been running for a few weeks.
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
sh: 1: PATH: not found
hm2_eth: 10.10.10.10: INFO: Hardware address (MAC): 00:60:1b:10:40:6c
hm2_eth: discovered 7I76E-16
hm2/hm2_7i76e.0: Low Level init 0.15
hm2/hm2_7i76e.0: Smart Serial Firmware Version 43
Waiting for component 'hm2_eth' to become ready.Board hm2_7i76e.0.7i76.0.0 Hardware Mode 0 = standard
.Board hm2_7i76e.0.7i76.0.0 Software Mode 0 = io_spin
.Board hm2_7i76e.0.7i76.0.0 Software Mode 1 = io_ana_spin
.Board hm2_7i76e.0.7i76.0.0 Software Mode 2 = io_enc_ana_spin_fv
................board fails HM2 registration
hm2_eth: in hm2_eth_reset
.sh: 1: PATH: not found
.hm2_eth: rtapi_app_main: Resource temporarily unavailable (-11)
twopass: load_the_modules cmd=<orig_loadrt hm2_eth [concat board_ip="10.10.10.10"] [concat config=" num_encoders=3 num_pwmgens=0 num_stepgens=5 sserial_port_0=2xxxx"]>
waitpid failed /home/plasma2/linuxcnc-pla/bin/rtapi_app hm2_eth
/home/plasma2/linuxcnc-pla/bin/rtapi_app exited without becoming ready
insmod for hm2_eth failed, returned -1
hm2: unloading
Note: Using POSIX realtime
LinuxCNC terminated with an error. You can find more information in the log:
/home/plasma2/linuxcnc_debug.txt
06 Nov 2021 02:59 #225461
Replied by rodw on topic 7i76e not loading
Actually this might be OK again.
I was building the debs and trying to use a RIP version in a different instance in ~/linuxcnc-pla at the same time.
Id has happened a couple of times in the last day or so though.
Time to create page: 0.161 seconds
