Setting up Mesa 7i96
17 Nov 2021 14:16 #226734
by imslo
Setting up Mesa 7i96 was created by imslo
I am trying to setup a Mesa 7i96 board. The step and dir pins have both "+" and "-" connections. Which should i use?
How do I set up a probe? Run "+" 5 volts through the probe to an input pin?
Steve
Steve
- Thank you received: 5946
17 Nov 2021 15:44 #226748
Replied by tommylight on topic Setting up Mesa 7i96
Moved to "driver boards".
17 Nov 2021 15:52 - 17 Nov 2021 15:54 #226749
Replied by PCW on topic Setting up Mesa 7i96
Step drive wiring depends on your drives.
For normal step/dir drives with Step+,Step-,Dir+,Dir- inputs
I would use the 7I96's +5 to drives Step+ and Dir+ and the
7I96's Step- and Dir- to the drives Step- and Dir-.
For high speed servo drives, I would use differential wiring
with the 7I96's Step-, Dir-, Step+, Dir+ going to the drives
Step-, Dir-, Step+, Dir+.
Probe wiring depends on the probe type (tool touch off devices that make
electrical contact to the tool need different wiring than isolated contact probes)
Last edit: 17 Nov 2021 15:54 by PCW.
17 Nov 2021 16:15 #226759
by imslo
Replied by imslo on topic Setting up Mesa 7i96
I'Im sorry I don't understand the answer. Right now I'm running a Hobby cnc board through the parallel port.. The new system will have 3 separate drivers. I dont"t know what they are they are not before me. On my present system I simply hooked the parallel port cable to the board there was no concern about poliarity.
The probe I am using is a NO mementary push button switch.
17 Nov 2021 16:28 - 17 Nov 2021 16:28 #226761
Right, so you would need to look at the drive connection specifications
before any attempt to wire this.
For a probe that's an isolated switch, you would wire one side to +5V (or +24V)
and the other side to a 7I96 isolated input. This assumes the 7I96 input common
(P3 pin 12) is gnd
(P3 pin 12) is gnd
Last edit: 17 Nov 2021 16:28 by PCW.
17 Nov 2021 16:33 #226762
by imslo
Thanks for the reply
Steve
Steve
Time to create page: 0.230 seconds
