7i97 no ethernet connection
30 Nov 2021 01:53 #227970
by Arnold
Replied by Arnold on topic 7i97 no ethernet connection
4? See if ethtool is installed
not installed, so I did, but first update
So I installed athtool....
To see if it is ok=
PCW recommendation-->Used it on eno1 (my interface)
Not working
arnold@desktop-cnclan:~$ sudo ethtool --version
[sudo] password for arnold:
sudo: ethtool: command not found
arnold@desktop-cnclan:~$ sudo apt-get update
Hit:1 http://security.debian.org/debian-security buster/updates InRelease
Hit:2 http://deb.debian.org/debian buster InRelease
Hit:3 http://deb.debian.org/debian buster-updates InRelease
Hit:4 http://www.linuxcnc.org buster InRelease
Reading package lists... Done
arnold@desktop-cnclan:~$ sudo apt-get install ethtool
Building dependency tree
Reading state information... Done
The following NEW packages will be installed:
ethtool
0 upgraded, 1 newly installed, 0 to remove and 55 not upgraded.
Need to get 121 kB of archives.
After this operation, 402 kB of additional disk space will be used.
Get:1 http://deb.debian.org/debian buster/main amd64 ethtool amd64 1:4.19-1 [121 kB]
Fetched 121 kB in 0s (403 kB/s)
Selecting previously unselected package ethtool.
(Reading database ... 86074 files and directories currently installed.)
Preparing to unpack .../ethtool_1%3a4.19-1_amd64.deb ...
Unpacking ethtool (1:4.19-1) ...
Setting up ethtool (1:4.19-1) ...
Processing triggers for man-db (2.8.5-2) ...
To see if it is ok=
ethtool version 4.19
arnold@desktop-cnclan:~$ sudo ethtool -C eno1 rx-usecs 0
arnold@desktop-cnclan:~$ ping 192.168.1.121
PING 192.168.1.121 (192.168.1.121) 56(84) bytes of data.
From 10.10.10.11 icmp_seq=1 Destination Host Unreachable
From 10.10.10.11 icmp_seq=2 Destination Host Unreachable
From 10.10.10.11 icmp_seq=3 Destination Host Unreachable
From 10.10.10.11 icmp_seq=4 Destination Host Unreachable
From 10.10.10.11 icmp_seq=5 Destination Host Unreachable
From 10.10.10.11 icmp_seq=6 Destination Host Unreachable
From 10.10.10.11 icmp_seq=8 Destination Host Unreachable
From 10.10.10.11 icmp_seq=9 Destination Host Unreachable
From 10.10.10.11 icmp_seq=11 Destination Host Unreachable
From 10.10.10.11 icmp_seq=14 Destination Host Unreachable
From 10.10.10.11 icmp_seq=15 Destination Host Unreachable
^C
--- 192.168.1.121 ping statistics ---
16 packets transmitted, 0 received, +11 errors, 100% packet loss, time 351ms
pipe 4
Not working
30 Nov 2021 02:04 - 30 Nov 2021 02:17 #227971
by Arnold
A bit more of my personal history:
Here the computer is connected to internet, working properly!
[/code][/code]
arnold@desktop-cnclan:~$ ethtool eno1
bash: ethtool: command not found
arnold@desktop-cnclan:~$ sudo ethtool eno1
Settings for eno1:
Supported ports: [ TP ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Full
Supported pause frame use: No
Supports auto-negotiation: Yes
Supported FEC modes: Not reported
Advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Advertised pause frame use: No
Advertised auto-negotiation: Yes
Advertised FEC modes: Not reported
Speed: 1000Mb/s
Duplex: Full
Port: Twisted Pair
PHYAD: 1
Transceiver: internal
Auto-negotiation: on
MDI-X: on (auto)
Supports Wake-on: pumbg
Wake-on: g
Current message level: 0x00000007 (7)
drv probe link
Link detected: yes
But Here I changed the connection to the configured for mesa 7i97
[code][code]arnold@desktop-cnclan:~$ sudo ethtool eno1
Settings for eno1:
1000baseT/Full
1000baseT/Full
Speed: 100Mb/s
Duplex: Full
Port: Twisted Pair
PHYAD: 1
MDI-X: on (auto)
Wake-on: g
drv probe link
Link detected: yes
Last edit: 30 Nov 2021 02:17 by Arnold.
30 Nov 2021 02:21 #227972
by Arnold
When connected to internet speed 1000mbs
When "connected" to the 7i97 through parameters in description, speed 100mbs and not communication possible "ping"
I really need a hand, I have no clue what is happenning
Sorry for the long thread
- Thank you received: 5948
30 Nov 2021 09:25 #227985
Replied by tommylight on topic 7i97 no ethernet connection
The PC side is OK, set the Mesa board to 10.10.10.10.
Read the manual, there is a jumper to be moved.
30 Nov 2021 11:48 #227994
by Arnold
The jumpers where w16 down, w17 down, manual specify (FIXED 192.168.1.12 as a default).....having no luck with that
I follow tommylight recomendation, so changed to FIXED FROM EEPROM, w10 down, w17 up. Manual said shipped default EEPROM is 10.10.10.10
But now:
What happens?
arnold@desktop-cnclan:~$ ping 10.10.10.10
PING 10.10.10.10 (10.10.10.10) 56(84) bytes of data.
64 bytes from 10.10.10.10: icmp_seq=1 ttl=64 time=0.516 ms
64 bytes from 10.10.10.10: icmp_seq=2 ttl=64 time=0.271 ms
64 bytes from 10.10.10.10: icmp_seq=3 ttl=64 time=0.270 ms
64 bytes from 10.10.10.10: icmp_seq=4 ttl=64 time=0.294 ms
64 bytes from 10.10.10.10: icmp_seq=5 ttl=64 time=0.272 ms
64 bytes from 10.10.10.10: icmp_seq=6 ttl=64 time=0.264 ms
64 bytes from 10.10.10.10: icmp_seq=7 ttl=64 time=0.276 ms
64 bytes from 10.10.10.10: icmp_seq=8 ttl=64 time=0.296 ms
64 bytes from 10.10.10.10: icmp_seq=9 ttl=64 time=0.269 ms
64 bytes from 10.10.10.10: icmp_seq=10 ttl=64 time=0.273 ms
64 bytes from 10.10.10.10: icmp_seq=11 ttl=64 time=0.288 ms
64 bytes from 10.10.10.10: icmp_seq=12 ttl=64 time=0.268 ms
^C
--- 10.10.10.10 ping statistics ---
12 packets transmitted, 12 received, 0% packet loss, time 195ms
rtt min/avg/max/mdev = 0.264/0.296/0.516/0.068 ms
But now:
arnold@desktop-cnclan:~$ sudo mesaflash --device 7i97 --readhmid
No 7I97 board found
What happens?
30 Nov 2021 12:19 #227999
by Arnold
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.8.2-11-g6a3d0a434
Machine configuration directory is '/home/arnold/linuxcnc/configs/basic7i97_2021-11-26'
Machine configuration file is 'basic7i97.ini'
INIFILE=/home/arnold/linuxcnc/configs/basic7i97_2021-11-26/basic7i97.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=XYZ
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
emc/iotask/ioControl.cc 702: can't load tool table.
Found file(REL): ./basic7i97.hal
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 10.10.10.10: INFO: Hardware address (MAC): 00:60:1b:17:00:43
hm2_eth: discovered 7I97
hm2/hm2_7i97.0: Low Level init 0.15
hm2/hm2_7i97.0: Smart Serial Firmware Version 43
hm2/hm2_7i97.0: 51 I/O Pins used:
hm2/hm2_7i97.0: IO Pin 000 (TB3-04): PWMGen #0, pin Out0 (PWM or Up) (Output)
hm2/hm2_7i97.0: IO Pin 001 (TB3-08): PWMGen #1, pin Out0 (PWM or Up) (Output)
hm2/hm2_7i97.0: IO Pin 002 (TB3-12): PWMGen #2, pin Out0 (PWM or Up) (Output)
hm2/hm2_7i97.0: IO Pin 003 (TB3-16): PWMGen #3, pin Out0 (PWM or Up) (Output)
hm2/hm2_7i97.0: IO Pin 004 (TB3-20): PWMGen #4, pin Out0 (PWM or Up) (Output)
hm2/hm2_7i97.0: IO Pin 005 (AN_ENA4): PWMGen #4, pin Not-Enable (Output)
hm2/hm2_7i97.0: IO Pin 006 (TB3-24): PWMGen #5, pin Out0 (PWM or Up) (Output)
hm2/hm2_7i97.0: IO Pin 007 (AN_ENA5): PWMGen #5, pin Not-Enable (Output)
hm2/hm2_7i97.0: IO Pin 008 (AN-ENA0..3): PWMGen #0, pin Not-Enable (Output)
hm2/hm2_7i97.0: IO Pin 009 (TB1-01/TB1-09): Muxed Encoder #0, pin Muxed A (Input)
hm2/hm2_7i97.0: IO Pin 010 (TB1-04/TB1-12): Muxed Encoder #0, pin Muxed B (Input)
hm2/hm2_7i97.0: IO Pin 011 (TB1-07/TB1-15): Muxed Encoder #0, pin Muxed Index (Input)
hm2/hm2_7i97.0: IO Pin 012 (TB1-17/TB2-01): Muxed Encoder #1, pin Muxed A (Input)
hm2/hm2_7i97.0: IO Pin 013 (TB1-20/TB2-04): Muxed Encoder #1, pin Muxed B (Input)
hm2/hm2_7i97.0: IO Pin 014 (TB1-23/TB2-07): Muxed Encoder #1, pin Muxed Index (Input)
hm2/hm2_7i97.0: IO Pin 015 (TB2-09/TB2-17): Muxed Encoder #2, pin Muxed A (Input)
hm2/hm2_7i97.0: IO Pin 016 (TB2-12/TB2-20): Muxed Encoder #2, pin Muxed B (Input)
hm2/hm2_7i97.0: IO Pin 017 (TB2-15/TB2-23): Muxed Encoder #2, pin Muxed Index (Input)
hm2/hm2_7i97.0: IO Pin 018 (Internal EncMux): Muxed Encoder Select #0, pin Mux Select 0 (Output)
hm2/hm2_7i97.0: IO Pin 019 (TB5-13/TB5-14): SSR #0, pin Out-00 (Output)
hm2/hm2_7i97.0: IO Pin 020 (TB5-15/TB5-16): SSR #0, pin Out-01 (Output)
hm2/hm2_7i97.0: IO Pin 021 (TB5-17/TB5-18): SSR #0, pin Out-02 (Output)
hm2/hm2_7i97.0: IO Pin 022 (TB5-19/TB5-20): SSR #0, pin Out-03 (Output)
hm2/hm2_7i97.0: IO Pin 023 (TB5-21/TB5-22): SSR #0, pin Out-04 (Output)
hm2/hm2_7i97.0: IO Pin 024 (TB5-23/TB5-24): SSR #0, pin Out-05 (Output)
hm2/hm2_7i97.0: IO Pin 025 (Internal InMux0): SSR #0, pin AC Ref (internal) (Output)
hm2/hm2_7i97.0: IO Pin 026 (Internal InMux1): InMux Input Mux #0, pin addr0 (Output)
hm2/hm2_7i97.0: IO Pin 027 (Internal InMux2): InMux Input Mux #0, pin addr1 (Output)
hm2/hm2_7i97.0: IO Pin 028 (Internal InMux3): InMux Input Mux #0, pin addr2 (Output)
hm2/hm2_7i97.0: IO Pin 029 (Internal InMuxData): InMux Input Mux #0, pin addr3 (Output)
hm2/hm2_7i97.0: IO Pin 030 (TB4-15/TB4-16): InMux Input Mux #0, pin muxdata (Input)
hm2/hm2_7i97.0: IO Pin 031 (TB4-17/TB4-18): IOPort
hm2/hm2_7i97.0: IO Pin 032 (TB4-17/TB4-18): IOPort
hm2/hm2_7i97.0: IO Pin 033 (P1-01): IOPort
hm2/hm2_7i97.0: IO Pin 034 (P1-02): IOPort
hm2/hm2_7i97.0: IO Pin 035 (P1-03): IOPort
hm2/hm2_7i97.0: IO Pin 036 (P1-04): IOPort
hm2/hm2_7i97.0: IO Pin 037 (P1-05): IOPort
hm2/hm2_7i97.0: IO Pin 038 (P1-06): IOPort
hm2/hm2_7i97.0: IO Pin 039 (P1-07): IOPort
hm2/hm2_7i97.0: IO Pin 040 (P1-08): IOPort
hm2/hm2_7i97.0: IO Pin 041 (P1-09): IOPort
hm2/hm2_7i97.0: IO Pin 042 (P1-11): IOPort
hm2/hm2_7i97.0: IO Pin 043 (P1-13): IOPort
hm2/hm2_7i97.0: IO Pin 044 (P1-15): IOPort
hm2/hm2_7i97.0: IO Pin 045 (P1-17): IOPort
hm2/hm2_7i97.0: IO Pin 046 (P1-19): IOPort
hm2/hm2_7i97.0: IO Pin 047 (P1-21): IOPort
hm2/hm2_7i97.0: IO Pin 048 (P1-23): IOPort
hm2/hm2_7i97.0: IO Pin 049 (P1-25): IOPort
hm2/hm2_7i97.0: registered
hm2_eth: in hm2_eth_reset
hm2_eth: HostMot2 ethernet driver unloaded
hm2: unloading
Debug file information:
cannot gain I/O privileges - forgot 'sudo make setuid'?
Note: Using POSIX non-realtime
./basic7i97.hal:225: Unknown command '3600'
3549
Stopping realtime threads
Unloading hal components
Info report created by linuxcnc_info:
The file: /tmp/linuxcnc_info.txt
30 Nov 2021 12:35 #228000
by Arnold
30 Nov 2021 13:58 #228007
Attach the files here, not on a third party website.
Now you have everything set up properly, except you are using a generic kernel that does not work for machine control.
And it looks like you have Intel ethernet, but we'll get back to it later.
First, what does
uname -a
say?
First, what does
uname -a
say?
The following user(s) said Thank You: Arnold
30 Nov 2021 16:07 #228033
Replied by PCW on topic 7i97 no ethernet connection
That should be
mesaflash --device 7i97 --addr 10.10.10.10 --readhmid
That should be
30 Nov 2021 17:16 #228039
by Arnold
Why i am no getting that right?
thanks!!
That should be
arnold@desktop-cnclan:~$ ~$ sudo mesaflash --device 7i97 --readhmid
bash: ~$: command not found
thanks!!
Time to create page: 0.311 seconds
