Mesa 7i76e I/O filed power from onboard 5v regulator?
10 Dec 2021 06:21 #228756
by Eyecon
Mesa 7i76e I/O filed power from onboard 5v regulator? was created by Eyecon
I want to use 5v power on the field power input because I’m using 5v proximity sensors, does anyone know if I could use the onboard regulated 5v power to feed the field voltage input pins? I understand of course that in this case I have to move W1 to the right in order to split field voltage input from Vin.
10 Dec 2021 15:15 #228781
Replied by PCW on topic Mesa 7i76e I/O filed power from onboard 5v regulator?
VIN needs to be 8V or more but field power can be 5V to 32V
- Thank you received: 5945
10 Dec 2021 17:12 #228787
Replied by tommylight on topic Mesa 7i76e I/O filed power from onboard 5v regulator?
Deleted my previous post to avoid confusion, it was wrong.
Thank you, PCW.
Thank you, PCW.
Time to create page: 0.138 seconds
