MESA 7I76e power shorted
- Jalapeno56
- Thank you received: 17
02 Jan 2022 21:40 #230575
by Jalapeno56
MESA 7I76e power shorted was created by Jalapeno56
I'm a newbie with cnc, but good with electronics. This is my first go at building a cnc plasma cutter. I am using a standard 24v power supply hooked to pins 5 & 8 on TB1. Upon first time power applied, my power supply showed .83v, indicating a short. I disconnected power and began troubleshooting, ending up having everything disconnected and I still show a short of .1 ohms between pins 5 & 8. No led's have lit up, all jumpers are in correct position according to info I found on this site. W1 in left position shows short, W1 in right position does not short pins 5 & 8 but still no led's lighting up. The board shows no burnt marks and I never saw or smelled any magic smoke. This is a brand new board from Portugal (USA was out of stock). Any ideas or power side schematic to help me get this fixed?
Thanks!
Bryan
Thanks!
Bryan
- Thank you received: 5942
02 Jan 2022 22:52 - 02 Jan 2022 22:53 #230588
Replied by tommylight on topic MESA 7I76e power shorted
The power supply wires were reversed.
Last edit: 02 Jan 2022 22:53 by tommylight.
- Jalapeno56
03 Jan 2022 00:03 #230595
by Jalapeno56
Replied by Jalapeno56 on topic MESA 7I76e power shorted
No sir, I just triple checked that. I even checked the output with a voltmeter in case the labels were wrong.
- Jalapeno56
03 Jan 2022 00:12 #230596
by Jalapeno56
Does this mean the board is not fixable?
03 Jan 2022 00:37 #230599
It is either that or you wired the power while the power supply was on.
You might want to wait a bit for PCW to see this, he is the owner of Mesa and a valued member of this forum, he is also extremely helpful.
03 Jan 2022 01:02 #230600
Replied by PCW on topic MESA 7I76e power shorted
If the short between TB1 pins 5 and TB1 pin 8 is only there when W1 is in the
left hand position, either one or more of the output driver chips are damaged
or the field power TVS diode has been damaged.
- Jalapeno56
03 Jan 2022 02:56 #230611
by Jalapeno56
Thank you for the input guys! I guess I'll get a new board ordered tomorrow
Time to create page: 0.127 seconds
