7i80 Resource temporarily unavailable
13 Jan 2022 15:11 #231671
by billykid
7i80 Resource temporarily unavailable was created by billykid
hi, my 7i80 lately emits this message "Resource temporarily unavailable" but not always. the power supply is good 5.08 volts 5 amps, the cable I tried to change it but it is the same. I am attaching the results of "ip a" when it works and not but they look the same. the interfaces file and linuxcnc report. if I turn off the 7i80 and turn it back on it usually works without ever giving errors. regards Mauro
13 Jan 2022 15:49 #231673
Replied by PCW on topic 7i80 Resource temporarily unavailable
I would disable IPV6 on eth0
13 Jan 2022 16:18 #231676
by billykid
Replied by billykid on topic 7i80 Resource temporarily unavailable
Removed but nothing has changed.
13 Jan 2022 16:28 #231677
Whenever I've seen that error its related to some network change on the host PC
If you are not losing the 7I80 link, its probably unrelated to the 7I80
13 Jan 2022 16:38 #231678
by billykid
the interfaces file looks ok? i will do some tests anyway once reset then it works great. there is certainly something wrong with the network ... I had to put rfkill unblock for the wifi network otherwise it was soft blocked. now it's OK I rewrite when I can do something thank you
27 Jan 2022 13:50 #233275
by billykid
now it seems to go regularly. I had Megasync on startup, it probably crashed the 7i80. I have removed auto-start for Mega and it hasn't given any more problems.
28 Jan 2022 21:01 #233408
by billykid
nooo I spoke too soon!!! the problem always exists.
the pc is nuc 7i3 bnh driver e1000e I am attaching the command ethtool -i eth0
Time to create page: 0.233 seconds
