- Hardware & Machines
- Driver Boards
- What Mesa interface to use for 4-20mA input. Starting with a 7i76e
14 Jan 2022 21:12 #231797
by tupshin
Hello,
I'm building a 3 (or maybe 4) axis CNC based around a 7i76E. I'm interested in measuring current from various devices and getting that into LinuxCNCs. It looks like most of the appropriate devices (affordable Hall Effect current sensors) output either a 4-20mA signal or a +-4V signal.
From my relatively inexperienced eyes, it looks like I can wire the 4V ones directly into the 7i76E inputs, but that I would need other hardware in order to handle the 20mA signals.
For example, here are two of the devices I'm looking at using:
+-4V
and
4-20mA
So
+-4V
and
4-20mA
So
- Can I read the fist one directly with a 7I76E?
- Am I right in thinking that the second would require a 7I47(S)? They are the only cards that appear to mention 20mA signals
- Do those two cards play well together, or should I be considering something completely different?
14 Jan 2022 21:29 - 14 Jan 2022 21:30 #231802
Replied by rodw on topic What Mesa interface to use for 4-20mA input. Starting with a 7i76e
When I looked at this (for higher currents) I looked at using a ACS758 current sensor coupled with a LM358 amplifier module to step up the voltage.
That would allow reading the voltage on the 7i76e analog inputs. You would have to decide if the 7i76e accuracy was adequate for your needs
A more accurate method would be to use a Mesa THCAD-5 to measure the 5v voltage and send it to an encoder input like we do with plasma torch voltage. the ohmic.comp would give you a code example to work with.
Last edit: 14 Jan 2022 21:30 by rodw.
14 Jan 2022 22:33 #231812
Replied by PCW on topic What Mesa interface to use for 4-20mA input. Starting with a 7i76e
A 7I87 would be one solution, This has six +-10V 12 bit resolution analog
input channels and connects to the 7I76E's SSerial expansion port.
Mesa is currently out of stock but more are being built
14 Jan 2022 23:44 #231821
by BigJohnT
Replied by BigJohnT on topic What Mesa interface to use for 4-20mA input. Starting with a 7i76e
15 Jan 2022 00:45 #231836
by tupshin
Replied by tupshin on topic What Mesa interface to use for 4-20mA input. Starting with a 7i76e
Thanks for this, very helpful. The 7I87 looks like a great solution. I went ahead and grabbed the one JT has.
- Driver Boards
Time to create page: 0.081 seconds
