Mesa 7i97 on Simodrive 611 + glass scales
15 Jan 2022 00:10 #231827
by einarak
Mesa 7i97 on Simodrive 611 + glass scales was created by einarak
I´m retrofitting an old DMU50 to Mesa 7i97, it has Simodrive 611 servo drivers which are I guess closed loop since the AC motors have encoders connected to the drivers. It also has LS486 Glass scales on all axis, which are/were connected to the TNC124 that is being replaced with Mesa and LinuxCNC.
As said before, the encoder on each motor is connected to the servo driver and I assume it has to be that way for the drivers to work.
So should I wire the glass scales to the 7i97 board? Doesn´t it create a conflict if both the Simo driver and 7i97 are trying to control the motor closed loop?
15 Jan 2022 00:30 #231834
Replied by PCW on topic Mesa 7i97 on Simodrive 611 + glass scales
If the Simodrive 611s are running in analog velocity mode,
you must connect the glass scales to the 7I97/LinuxCNC
for position feedback.
The following user(s) said Thank You: einarak
15 Jan 2022 10:39 #231883
by einarak
Replied by einarak on topic Mesa 7i97 on Simodrive 611 + glass scales
Thanks PCW!
Time to create page: 0.087 seconds
