7i76e damaged driver output
- Jalapeno56
- Thank you received: 17
22 Jan 2022 01:33 #232720
by Jalapeno56
Replied by Jalapeno56 on topic 7i76e damaged driver output
That is very possible. This CVR im using is made for up to 7.5Kv @ 13K amps on a regular basis. It is WAY MORE robust than i needed for this test.
- ALittleOffTheRails
- User is blocked
- Thank you received: 65
22 Jan 2022 02:02 #232721
by ALittleOffTheRails
Replied by ALittleOffTheRails on topic 7i76e damaged driver output
Never had an issue with genuine Meanwell PSU.
I'm also using a couple of Weidmuller PSUs as well. I'm not expecting any issue with these either.
The following user(s) said Thank You: Jalapeno56
- Jalapeno56
22 Jan 2022 02:07 #232722
by Jalapeno56
Thanks for the input guys!!! I'll order a Meanwell and see if that helps my issues. Im using a Siemens currently and have never had issues with them before, but maybe I just got a bad one....
- Jalapeno56
22 Jan 2022 02:30 #232723
by Jalapeno56
@ PCW could the current spike from the power supply be putting the 7I76e into a protection mode of some sort?
22 Jan 2022 03:42 #232724
Replied by PCW on topic 7i76e damaged driver output
There should be no current spike.
Are you switching the DC side of the field power? (you should not)
Also a 1 or 2 Amp 24V supply is more than enough
- Jalapeno56
22 Jan 2022 16:28 #232795
by Jalapeno56
I am switching the A/C side of the power supply. I am also using the 24v for my limit/home and thc switches, so the 14.2 Mean well should be more than enough!
Thank you!
Thank you!
Time to create page: 0.320 seconds
