Which mesa boards to choose for my mill?
26 Jan 2022 14:19 #233171
by EddySPalm
Which mesa boards to choose for my mill? was created by EddySPalm
I have yet to find some kind of guide or walkthrough regarding what mesa cards will be suitable for which applications/scenarios.
Probably because reading the boards' specifications is second nature to most people
I have an EMCO F1P CNC mill which I have been running for a little while with a HobbyCNC Pro driver board and open loop steppers. This mill definitely deserves better, so out goes the HobbyCNC and steppers, and in goes 400W AC servos from DMM with Dyn2 drivers.
I have figured out that the 7I76 will take care of all my needs with regards to I/O's, encoder (for the spindle), 0-10V (also for the spindle), but there are a few questions which remains unanswered:
- Which version of the 7I76 should I choose?
- I see people are often pairing the 7I76 with another board called 5I25; what for? Should I?
The computer I am using is a very capable one, and it scored really well on the latency test. It has a parallel port, an ethernet port and a bunch of USB ports (if that's at all relevant).
So, which 7I76 board to go for (parallel vs ethernet, sinking vs sourcing outputs)?
Thanks in advance
Thanks in advance
- Thank you received: 5934
26 Jan 2022 15:23 #233178
Replied by tommylight on topic Which mesa boards to choose for my mill?
I would go for the 7i76E and be done with it.
The sourcing/sinking will change the wiring for inputs/outputs regarding the common used, but any of them will work if you have to do the wiring from scratch, and if you happen to have wrong proximity sensors (PNP instead of NPN and vice versa), a single resistor per sensor should take care of that.
26 Jan 2022 19:44 #233214
by EddySPalm
Replied by EddySPalm on topic Which mesa boards to choose for my mill?
Hi Tommy. Thank you for your reply
So you would choose the ethernet version, and you would not go with the 5I25. Just for the purpose of learning a little, would you care to explain just a little bit about why you would do so ? Being a total newb, I just want to understand what the 5I25 would do/not do for me, and why I should choose the ethernet version over the DB25 version.
Is the setup the same across all versions ?
26 Jan 2022 19:48 #233217
by EddySPalm
And by setup I mean in LinuxCNC, just to be clear
26 Jan 2022 20:25 #233224
The Mesa 7i76E is very close or exactly like a 7i92 and a 7i76.
7i92 is the same as 5i25 that uses PCI slot and requires a DB25 cable for connection to 7i76, or same as 6i25 that uses PCI-E slot and again needs a cable.
Setting up LinuxCNC differs in literally changing the card number in the PncConf or editing the ini file.
26 Jan 2022 23:18 #233242
by EddySPalm
Okey, so I see why I should go with an ethernet card now, thanks.
I still don't understand why people are combining different cards though. Does it give functionality that the 7I76 don't have ?
27 Jan 2022 07:05 #233257
by EddySPalm
Okey, fantastic,
So the whole "taking the load off of the computers' CPU" part is done by the 7I76 alone then? No performance gains from combining it with other cards?
What is there in the 5I25 card that makes so many people combine it with the 7I76?
