Bitfile 7i92 with 7i77 on p2 and gpios on p1
  • DoWerna
  • DoWerna's Avatar Topic Author
  • Elite Member
  • Elite Member
27 Jan 2022 21:38 #233318 by DoWerna
my lathe gets a 7i92 in combination with a 7i77.
would like to use the P1 on the 7i92 for a small panel.
if i see this right now i would need a bitfile:
IO Connections for P2
Pin#  I/O   Pri. func    Sec. func       Chan      Pin func        Pin Dir
 1      0   IOPort       SSerial          0        TXEn2           (Out)
14      1   IOPort       SSerial          0        TXData2         (Out)
 2      2   IOPort       SSerial          0        RXData2         (In)
15      3   IOPort       SSerial          0        TXData1         (Out)
 3      4   IOPort       SSerial          0        RXData1         (In)
16      5   IOPort       SSerial          0        TXData0         (Out)
 4      6   IOPort       SSerial          0        RXData0         (In)
17      7   IOPort       MuxedQCountSel   0        MuxSel0         (Out)
 5      8   IOPort       MuxedQCount      0        MuxQ-A          (In)
 6      9   IOPort       MuxedQCount      0        MuxQ-B          (In)
 7     10   IOPort       MuxedQCount      0        MuxQ-IDX        (In)
 8     11   IOPort       MuxedQCount      1        MuxQ-A          (In)
 9     12   IOPort       MuxedQCount      1        MuxQ-B          (In)
10     13   IOPort       MuxedQCount      1        MuxQ-IDX        (In)
11     14   IOPort       MuxedQCount      2        MuxQ-A          (In)
12     15   IOPort       MuxedQCount      2        MuxQ-B          (In)
13     16   IOPort       MuxedQCount      2        MuxQ-IDX        (In)
IO Connections for P1
 1     17   IOPort       None
14     18   IOPort       None
 2     19   IOPort       None
15     20   IOPort       None
 3     21   IOPort       None
16     22   IOPort       None
 4     23   IOPort       None
17     24   IOPort       None
 5     25   IOPort       None
 6     26   IOPort       None
 7     27   IOPort       None
 8     28   IOPort       None
 9     29   IOPort       None
10     30   IOPort       None
11     31   IOPort       None
12     32   IOPort       None
13     33   IOPort       None
find only a 7i92_7i76x1D.pin
so for a 7i76 on p2 and gpios on p1
is there somewhere a ready bitfile for a 7i77 and simple gpios at p1
27 Jan 2022 21:43 - 27 Jan 2022 22:04 #233320 by PCW
You should be able to use a 7i77x2 configuration as long as you disable
the encoders and sserial ports on P1, something like:
config="num_encoders=6 sserial_port_0=000xxx"
When the special functions (encoder, PWM, Step/Dir, SSerial etc)
on a pin are disabled, that pin reverts to simple GPIO.
Last edit: 27 Jan 2022 22:04 by PCW.
The following user(s) said Thank You: DoWerna
Moderators: PCWjmelson
Time to create page: 0.209 seconds
