Usage of index signal only from encoders with 7i76e
- mydani
- Thank you received: 9
26 Feb 2022 14:54 #235849
by mydani
Usage of index signal only from encoders with 7i76e was created by mydani
Hi guys,
I am currently playing around with a machine which uses 5 steppers with encoders.
The original control only used the encoder index signals for referencing (besides 5 limit switches).
Do you think it's possible to use the index signal in the same way using a 7i76e?
Homes against the limit switch, then uses the index signal for precise home position.
The 7i76e only has one "real" encoder possibility, therefore I'd need to use the field I/O for the index signals.
Regards
Daniel
Regards
Daniel
- Thank you received: 5252
26 Feb 2022 19:39 - 26 Feb 2022 19:52 #235863
Replied by PCW on topic Usage of index signal only from encoders with 7i76e
I think its possible but probably requires a hal component to simulate index behaviour.
(Latching the pulse and having tri-state output). You might be able to use the software
encoder component to provide that simple logic. The search for index move needs to be
slow enough that you are guaranteed to sample the index at the servo thread rate.
Last edit: 26 Feb 2022 19:52 by PCW. Reason: format
The following user(s) said Thank You: mydani
- mydani
26 Feb 2022 19:59 #235865
by mydani
Replied by mydani on topic Usage of index signal only from encoders with 7i76e
I'd drive it slow enough so the index will be seen, for sure.
Then the comp could either just reset the index-enable and I could link the index signal directly to the IO pin, or I could read the index and latch it until next index-enable comes. Either way, should work.
Thanks again PCW.
Thanks again PCW.
26 Feb 2022 20:09 #235868
Forgot one detail, you must use this option:
HOME_INDEX_NO_ENCODER_RESET
Since the step position feedback will not be cleared on index
This also requires using LinuxCNC master AFAIK
- mydani
26 Feb 2022 20:12 #235869
by mydani
Thank you. I am getting old... you know why? Once upon a time I wrote a component (attached), which just switches the input during the normal homing sequence. Had used it with a stepper + index pulse (sensor at a pulley) setup. Should be pretty reusable.
If not I will switch back to your suggestion.
Regards,
Daniel
Regards,
Daniel
Time to create page: 0.119 seconds
